New Clutch
New Clutch
Well, I just installed a SBC in my rig. I replaced the flywheel with a new one from Cummins. Wow, what a fun job that was ! A pretty painless job. I had all the right tools and took less than 6 hours to replace. I have one question to anybody that has a SBC, I'm getting some chatter when releasing the clutch into 3rd gear. I'm thinking I may have a bad output shaft bearing on the transmission ! Any info would be appreciated.
Chip
Chip
Re:New Clutch
Was your flywheel flat? If your flywheel has any taper to it that clutch wont last long. (Might be the reason for the chatter) The flywheel needs to be stone ground flat. Taking it to a machine shop and having it lathe cut is not recommended.
Thats all I can think of
Take care
Mark
Take care
Mark
Re:New Clutch
your shift into 3rd ought to be pretty fast (not room for a lot of slip) so....Iwould check all other things b4 the clutch...if it was going to act this way it would do so in other gears also.
Re:New Clutch
Thumper549,
Yea, it is a short shift- it only does it when I engage the clutch in 3 rd gear then it goes away. It's not a slip of the clutch but a chatter. Maybe I need to check or replace the output shaft bearing on the aft end of the transfer case where the rear drivshaft goes into the transfer case.
Chip
Chip
Re:New Clutch
Which South Bend Clutch do you have?
Sounds like you are trying to start off in 3rd gear.
Some chatter is normal,, especially is you launch in a high gear, or have to slip the clutch at low RPM, with a big load.
Merrick
Merrick
Re:New Clutch
Yep, only in 3rd gear-- I have the mu 0900 CON O. If I keep the rpm's up around 2k when I change to 3rd, it doesn't seem to be as bad !!
Chip
Chip
Re:New Clutch
Give it some time, and if it doesn't get better with 500-700 miles, Give Peter at South Bend Clutch a call. These Clutchs act funky when breaking them in. Most people report slipping in the first 1,000 miles. Mine did, but with miles, it kept holding stronger everyday.
Like I said, give it sometime, if it doesn't get better, or if another problem arises,, you will definatly need to look into it.
Merrick
Merrick
Re:New Clutch
Thanks for the input Merrick, Oh, I'll be watching everyday, I crawl under quite a bit checking the new rear main seal that I also replaced--- hence the reason for replacing a throughly oil soaked disk. So far, so good, no leaks.
Chip
Chip
Re:New Clutch
5 years, 100K. Whicj ever comes first. Granted the previous owner didn't void the warrenty with injectors or a "hot" box,, or any other performance modification. Yes, it should be.
Chip,, Watch that leak very closely. Oil on the clutch will defiantly make alot of chatter, and will ultimatly lead to a clutch replacement.
Merrick.
Merrick.
Derek Crowl
08-20-2013 10:43 PM
Backwoods Bumpers
11-20-2007 08:01 AM
WACTD
07-25-2006 11:41 AM
