new to 24 valve, have a question
Old 02-17-2008, 07:31 PM
SuperiorRam's Avatar
Question new to 24 valve, have a question
hey there second geners im looking at a 01 3500 qc 4X4 6spd HO w/edge ez
my question is is there a chip that lets it rev more like the govenor spring like thoes found on the rotary and p-pump it just falls on its face where-as my 92revs like crazy
Old 02-17-2008, 07:43 PM
mishkaya's Avatar
There are several options out there, but I do know the Adrenaline will let you fuel as high as you like. However you do need to worry about valve float if you still have the stock springs.
mishkaya
Old 02-17-2008, 07:52 PM
JStull's Avatar
I know what you mean about the edge box with it falling flat around 2700 or so.
I had one on my '01 and sold that when I started running a Smarty. The Smarty seemed to pull hard to 3200 or so. I'd say I got another 400 or 500 rpm out of it over the comp on the top end.
If you want more than that, I can't help but I'd also worry about valve float. I just threw a set of 60# springs on my 12V because of that.
Take care,
Jason
Old 02-17-2008, 09:45 PM
JDGPULLER's Avatar
was the 01 you were looking at on ebay?
Old 02-17-2008, 09:52 PM
busa's Avatar
The Edge juice with attitude with level 6 will fuel to who nows what. Mine pulls to when I shift around 3300 or so.
Old 02-18-2008, 11:08 AM
JDGPULLER: was the 01 you were looking at on ebay?
no
busa: The Edge juice with attitude with level 6 will fuel to who nows what. Mine pulls to when I shift around 3300 or so.
i really don't want more power just more arrr's
Old 02-18-2008, 12:44 PM
busa's Avatar
no
Yeah, everybody says that at first
Old 02-18-2008, 02:46 PM
no no the first gen is too fast too pumped up and tooooooo bad on mileage
Old 02-18-2008, 07:53 PM
bump t bum BUMP
Old 02-18-2008, 08:25 PM
afoulk's Avatar
The only ones I know of that will raise the rpm range are the edge drag comp, edge juice/attitude ( I think they both max out at about 3600 or 3700rpms), the bluechip redline (4,000rpms I think), and the Quadzilla Adrenaline (4,000 atleast, probably higher depending on the downloadable programs quad comes up with).
Old 02-19-2008, 09:34 AM
98.5Hotrod's Avatar
Just remember you are flirting with disaster when you rev near or past 3400 with stock springs. They are rated at 3400rpm when new not when they have 150000 miles on them. If you plan on reving past 3000 to 3200 invest in some new springs. F1 makes excellant springs and cams, and injectors
Intercooler
06-04-2005 07:48 PM
piperca
33
05-11-2004 06:40 PM
skinsey
07-17-2003 05:47 PM
1320
05-17-2003 03:28 PM
phildog
04-02-2003 05:44 AM
Quick Reply: new to 24 valve, have a question
