needing a little info
Old 08-01-2010, 07:40 PM
blowinsmokeinKy's Avatar
Question needing a little info
my friend bought a truck that had a Smarty in it at one time,but there is no sign of it now or can u tell if it is still chipped....it is supposedly stuck in the 6th stage, is there anyway to see if it is really stuck or to get the code out..
Old 08-01-2010, 08:15 PM
Doj Dewd's Avatar
have to try another smarty on it i think. it should tell you the currently installed software # . . . .
Old 08-01-2010, 09:31 PM
BigGreen's Avatar
Try another programmer it will store the tune that is currently on it and load the one you want. It can't be a box though has to be a tuner. Only other option is dealership.
Old 08-02-2010, 01:50 PM
Admin Team Leader
Lary Ellis (Top)'s Avatar
They are vin locked so if the guy kept the Smarty he had to unload it from that truck first before he could sell or use it on another truck. My guess is the truck is stock.
Old 08-02-2010, 02:55 PM
I dont always get the death wobble, But when I do, I just buy a new truck.
teamroper08's Avatar
im just say i dont know for sure though..but if its stuck on the 6th power level from a smarty it will run like a sob but if it doesnt run anybetter than stock....then its stock and judging by what you have done to you truck yall should be able to tell between the two of them
Old 08-02-2010, 03:10 PM
BigGreen's Avatar
I would hope you could tell the difference in them or why buy a smarty. I was able to tell my truck had some kind of programmer on it as they spliced into the Map Sensor you could see the splices still in it.
And I agree can't imagine someone would leave a smarty on a truck when selling it as that discourages some people as they know what damage those can cause.
Old 08-02-2010, 07:48 PM
it's still stuck then....cause it will run with my truck and it's pushing over 400hp without a programmer
Old 08-02-2010, 08:22 PM
BigGreen's Avatar
There u go then do you both have the same gears.
jnall
06-25-2011 12:10 AM
Totallyrad
03-30-2008 03:27 PM
97on22s
02-12-2006 08:01 PM
JWFMOPAR
01-25-2006 09:59 AM
RiverMan
07-05-2003 04:23 PM
Quick Reply: needing a little info
