Need Trailer Brake Help
Old 04-20-2008, 05:15 PM
DieselNomad's Avatar
just hoping sombody has an idea for putting breaks on a 20ft. goose neck. the trailer has a walking beam axle from an old mobile home(i think) and is hydraulic drums, i would like to keep this setup. i have been told that theres electric over hydraulic, any help would be great.
Old 04-20-2008, 05:36 PM
With age comes the cage
Colo_River_Ram's Avatar
Check Out the photos on my profile, I installed a Carlisle elec./hyd actuator and disc brakes on my 42' GN.. What kind of shape is the drums/linings in..if they are worn out you might want to upgrade to disc this should be a bolt on option depending on your axles.. Both dexter and Carlisle make an elec/hyd actuator..The output pressure needed varies for the application((disc or drum), this is why i suggested the upgrade to the discs prior to ordering the unit(fixed pressure)..post some pics it will help to identify things..
Old 04-20-2008, 09:00 PM
colo
whats the cost and time to install if everything is good(im thinking that the drums are shot so need disc) so price on actuator and disc retro. thanks for the info and help, gettin me closer
Old 04-21-2008, 12:05 AM
pind's Avatar
Nomad
for pricing, try city spring in Edmonton 1-800-661-3843
These guys have been very helpful in the past, and they ship up here rather quickly too.
Lots of knowledge to be gained from talking to them as well. Prices are sometimes as good, sometimes better than Standen's or McCoy Bros.
Depending what I require, those are the three companies that I normally deal with.
Good Luck
Old 04-21-2008, 08:34 PM
Here is a link to dexter to help track down your axle info:
http://www.dexteraxle.com/products___literature
the Carlisle elec./ hyd actuator is going to run you about $650.
Do a Google for trailer part suppliers and compare prices
Installation time should be relatively quick as the kit will be bolt on.
The Actuator needs a relatively safe place to be mounted then it is simple (double flare) brake line hookups.. they offer kits with all of the components needed for the project, I used all SS as it was accessible besides it will hold up to road salts better..
Check Out this link and video as well:
http://www.trailerpart.com/kodiak.htm
Hope this info helps...
limitedslip
06-17-2013 05:37 PM
etn550
05-17-2010 11:28 PM
jmac1968
03-22-2010 10:30 PM
JIROBBI
07-24-2007 09:51 PM
triplem383
11-21-2005 07:59 AM
Quick Reply: Need Trailer Brake Help
