PDA
View Full Version : NEED TOW HOOKS, CANT FIND!!
j
10-21-2002, 03:34 PM
IS THERE ANY WAY TO GET TOW HOOKS ON THE FRONT OF MY TRUCK? I HAVE HEARD THAT THERE WAS AN OPTION FOR THEM FROM THE *******, BUT CANT SEEM TO FIND THEM. IS THERE ANYONE WHO MAKES THEM FOR DODGE 2500'S?
doug
10-21-2002, 04:05 PM
The 02's use a standard tow hook available from the dealer parts department.
j
10-21-2002, 04:25 PM
DOES IT MOUNT IN A FACTORY LOCATION, OR DO I NEED TO DRILL HOLES FOR THEM?..........
phox_mulder
10-21-2002, 04:40 PM
j.<br><br>Please turn off your caps.<br><br>It is like shouting, and considered rude.<br>Also hard on the eyes to read.<br><br>thanx<br><br>phox
phox_mulder
10-21-2002, 04:43 PM
Here is a good write up with photo's of the install.
Tow Hook Installation (http://dodgeram.org/ki4cy/4x4/tow_hook/tow_hooks.htm)
phox
Lary Ellis (Top)
10-21-2002, 04:44 PM
Yeah j that rude stuff is my job [laugh] Have you checked J.C. Whitney or Cabelas?. just a thought.
j
10-21-2002, 07:50 PM
phox............ sorry bout the caps, but our computers in our cars at work have it fixed in and always on so it's just easier for me to read what i wrote. thanks for the info on the hooks. for some reason my local ******* cant find them in his book of parts. i should know better than to listen to them anyway, which is why i drove an hour away when i bought my truck...... thanks again for the info.
Dieseldude4x4
10-22-2002, 05:06 AM
I put two chrome ones on mine with the spring clips. I think one hole was there and I had to drill the second. Use good grade eight bolts, don't get the cheap stuff. Put a heavy washer on the upper side of the frame to give you more bearing surface too. I'll add a pic if I can find one. Picked them up at a local tractor supply store if I remember right. You can also check www.awdirect.com. I buy a bit of stuff from them, they are not cheap but have quality stuff.<br>If the pic works, the hooks will be right in front of the oil filter gaurd. Let me know if you have any questions. Good luck.
Dieseldude4x4
10-22-2002, 05:13 AM
OOPS, had to go look up the pic. Here it is this time. The set up in the back ground is my remote oil system.
Commatoze
10-22-2002, 05:57 AM
Reunel (http://www.reunel.com/sshook.html) makes a nice set of stainless steel hooks. You can purchase them over the phone.
j
10-22-2002, 08:39 PM
thanks all for the help, now i have a bit more info to go with. i think i'll try the ******* first since i need to take the truck back for warranty work anyhow................ thanks again
