Need some info on turbo's and sticks please
Old 04-15-2009, 02:56 PM
TNRIPNROR's Avatar
Cool Need some info on turbo's and sticks please
Ok guys I've searched for a day or so and can't really find out what I wanna know here's what my plans is I'm wanting to step up to 150hp ddp or coaltrain injectors and match that with a turbo that I can still pull around 10,000lb no problems right now I have jammer 3 nozzles and a comp box and factory turbo and have no complants just want more power but I can tow fine with my set up box down of course so what turbo would be a good choice for me and would like to get by fairly cheap but not chesse cheap found a D-tech 62/12cm that don't sound so bad but want to here some knowledge from you guys alot of youns are smart so lets here it
Old 04-15-2009, 03:16 PM
Dglass89's Avatar
HTT 62/71/13SS would be a good charger for you IMO
Old 04-15-2009, 03:26 PM
DodgenIt's Avatar
Im a big fan of Industrial Injection's Phat Shaft 62. Im not sure of the compressor wheel size but I know the rest is 62/12 or 14 and the 12/14 cost the same so no extra cost there. Around 1550 is the price they told me for onea few weeks ago. The 14 might keep up with the DDP 150's better. I dont have one yet but I have a few friends that do and when enough $ is in my truck fund, i'll be going with the PS 62/14 and some I.I. 120hp sticks.
Donations accepted and appreciated.
Old 04-15-2009, 04:14 PM
JFlory's Avatar
I would go with a 62 in almost any varient with a set of 150's. Don't go with any turbo bigger. I had the bad luck of trying a 64/13/71 with M4's on my '01 5-speed and couldn't tow more than 8,500lbs, no matter what program setting I had it on.
J.D.
Old 04-15-2009, 06:21 PM
DodgenIt's Avatar
Why do you think you couldnt tow well?
Cause the 64 needed to be 62? Or cause your 13 needed to be 12 or 14?
I cant decide if i'll go with 62/12 or 14 when I add my 120 sticks.
Old 04-15-2009, 07:25 PM
Tate's Avatar
Because you don't get the low throttle boost to keep you temps down. The bigger turbos get hotter faster, but have a lower peak EGT than the stockers. A 62/65/12 would be a pretty good towing turbo, but will be hotter up top than a 62/71/14.
Old 04-15-2009, 07:57 PM
JohnX's Avatar
I run the ps62/12 turbo. Seems to spool pretty close to stock and cools pretty good when i'm fully loaded...18k gross. I would go with that one, hard to beat for the money. I'm only making 400hp or less, but I think it will keep up with me to at least the 500 mark.
Old 04-16-2009, 12:55 PM
JFlory's Avatar
It was because the 64 was too big. A 62 would have been fine. I have seen many trucks set up identical to the way mine was with the 62 and they had no problems. I just wanted to push the envelope and try a 64. I lost the gamble and was left with a heavy duty diesel that couldn't tow it's own wieght. Worst thing is how I told several people how great it was all winter long, then the first 80 degree day I was towing a friends sledpuller to a local event about 60miles away and it took everything I could do to keep things under 1300*. That was stopping 4 times to change settings on the smarty and playing with the Juice/Att. Even stock was too much. After talking with Don at F1 he confirmed that it had to be the 64mm wheel that was killing me.
My new rule is if you are towing more than 10k, do a 62/12,13,or14/65. If less than 10k 62/13,or 14/71.
J.D.
Old 04-17-2009, 12:31 AM
TNRIPNROR's Avatar
I think I'm gonna go with a 62/12 or 62/13 I'd say what about a bd super b how would one them handle 150 hp/ sticks
Old 04-17-2009, 01:10 AM
DodgenIt's Avatar
Ok so it was the 64 that killed ya. Well im set on 62 but still cant decide on 12 or 14cm exhaust side. Ill be adding 120 sticks, head studs and exhaust mani all at the same time as the turbo, and still have everything in my sig as well. I like racin but dont do it to often, and will pull between 4k and 13k with some steep grades at any givin time for work, also plow snow with a BOSS 9'2'' V so that can make for heavy loads as well, but 60 % drivin empty.
Im concerned that 12 will see too high top end egt's, and that the 14 will leave me blowin alot of smoke while towin around town.
What do you guys think?
Quicker spool / possible higher egt's?
Slower spool more smoke / lower egt's once I get goin?
6.6lEater
09-26-2010 01:24 PM
kdbvulcan
23
12-10-2008 09:51 AM
rootremblay
09-20-2007 10:00 PM
Common
05-22-2007 10:03 PM
Mini_Donkeys
04-19-2007 12:21 PM
Quick Reply: Need some info on turbo's and sticks please
