Need some help with wipers
Old 10-14-2008, 07:18 PM
dodgepower88's Avatar
Yesterday I started up my pickup in the cold (20 degrees), and after trying the windshield wipers they quit after three swipes. I made sure that they weren't frozen-stuck and scraped off "most" of the snow on the windsheild, but as i said they quit. After using the search function last night I tried setting the wipers on high speed and they worked, but they were way slower than they should've been.
Is there a common way to fix the wipers? or will I have to take it to a dealer
Any comments or suggestions are appreciated.
Phil
Old 10-15-2008, 12:29 PM
A.D.'s Avatar
If it is only happening every now and then, it could be the multifunction switch. Mine is acting up, and it affects wipers and blinkers every now and then. I guess though it would probably be the switch regardless if constant or not. 40-50 bucks online and easy fix.
Old 10-15-2008, 06:36 PM
Thanks, i'll see what I can find out
BlkBeard
03-21-2012 02:02 PM
Crallscars
03-05-2012 12:54 PM
SilverHoss99
10-31-2005 07:22 PM
JKM
03-04-2005 03:33 PM
Quick Reply: Need some help with wipers
