Need to replace Pyrometer probe?
Old Mar 2, 2010 | 02:13 PM
the.hogman's Avatar
My Banks pyrometer used to be accurate but now appears to be reading falsely (not enough half of what it should be). Where can I go to get a replacement probe? Seems like all I can find is the complete gauge setup. I just need the probe and the leads about 10" long like I currently have. Any direction would be appreciated.
Can I test the probe to see if I am having a gauge problem? What millivolts should it be putting out at what temperature? Maybe the probe is good and the gauge has crapped.
Last edited by the.hogman; Mar 2, 2010 at 03:16 PM. Reason: clarified some of the questions.
Old Mar 2, 2010 | 02:36 PM
DIESELWRKS's Avatar
IMO get rid of the banks and get a different gauge. or have you called banks and see if they will sell one seperate for you.
Old Mar 2, 2010 | 05:17 PM
guhfluh's Avatar
K-type thermocouples are cheap unless you have to get a namebrand, then you just pay for name. They all output the same voltage per temp. I custom ordered my own from Omega. They were quick to ship and EXCELLENT quality. My probe is not shielded and has super quick response. I use it in my turbo 2.4L Neon which sees more EGT than my truck and no issues with burnout yet at all. If it does I'll gladly buy another for ~$35 or so it costs.
Old Mar 4, 2010 | 09:33 PM
BLACKDRAGON's Avatar
I call banks or visit there web site. I had to get a new probe for my autometer phantom II and it takes a probe with a 10 pin connector.
Old Mar 5, 2010 | 01:59 PM
guhfluh's Avatar
Wierd. I'd like to see the diagram on that one. My Autometer had a normal two wire yellow and red lead K-type thermocouple. Way overpriced.
Old Mar 5, 2010 | 02:06 PM
Its like a regular autometer thermocouple but all the wires go into a connector that plugs into the back of gauge. Found it for 70 dollars. 5251 is part number of it
Old Mar 5, 2010 | 06:09 PM
rebal's Avatar
just replaced My old Isspro ,it was reading 300* first thing in the AM on a cold night before start up now things seem more better If you running high temps just replace the whole thing ,gauge /probe
Old Mar 6, 2010 | 11:35 PM
400Magnum's Avatar
How long of a probe should I get? I see them listed for 1.5 inches and 2.5 inches. I'd think the 1.5 would be more than long enough, but I've been wrong before.
Old Mar 7, 2010 | 08:15 AM
Imo I would get the 2.5 inch. Better to be a little long than too short. Im thinkin you should be able to adjust how far it goes in the manifold. But Ive been wrong before too.
Old Mar 7, 2010 | 05:16 PM
guhfluh's Avatar
Normally, yes you can adjust how far it goes into the manifold before swedging the manifold fitting. Depends on how the fitting to manifold is I guess.
I measured the manifold cross section, took half of that and added 3/4" to that for the fitting. W and to keep the tip in the middle of the manifold cross section. Not sure I remember what length I got though.
tomd
Dec 12, 2006 10:56 PM
Lenn
Mar 24, 2006 08:55 PM
TinJim
26
Sep 19, 2005 11:58 PM
GaCamper
Sep 5, 2004 08:40 AM
Homestead
Feb 9, 2003 03:14 AM
