Need performance help
Old 12-27-2009, 01:02 PM
Fire Rescue124's Avatar
going to get a 96 2wd 5speed reg cab this week and not sure what kinds of things i can do to it i know i need to upgrade the clutch. what are some other things that i can do to it on a budget for now. also on my 04 i had to upgrade the lift pump so how are the pumps on the 96 12V. i was told that the injector pump was bullet proof.
thanks for the input.
also some pics of you reg cab 2wd would be great to get some ideas on things to do to mine.
Old 12-27-2009, 01:25 PM
12v rollincole's Avatar
There is many things you can do to your truck on a budget. New fuel plate or grind your own, gsk 3-4, BHAF, do a search on these and there is endless amounts of info on here. As for the lift pump it is mechanical and should be good for along time.
good luck moding, matt
supranick750hp
07-20-2006 01:02 PM
dslpwr81
44
01-13-2006 11:32 PM
bbhzx12
11-11-2005 09:13 AM
SilverHoss99
10-10-2005 04:33 PM
jeepfun
01-14-2005 03:49 PM
Quick Reply: Need performance help
