Need more power!
Old 07-05-2007, 01:52 PM
smog2001's Avatar
Need more power!
I would like to get more power out of my marble crusher. Here is my problem. I tow, so I need to keep egt's low. Also, I am not ready to switch to twins. With the said, my truck is as follows: Edge w/attitude, Gorend trans, MBRP, Afe intake. No idea what my truck has for true power. But I am asumming pretty low compared to others. I wanted to keep this a reliable tow vehicle. I have stacked a smarty and had great power, however, EGT's were an issue. My toy hauler weights in at 13,500 if that helps.
Old 07-05-2007, 06:43 PM
JD311's Avatar
I geuss around the high 300s on hp and high 600s or low 700s on the tq.my 02 has the edge attitude system and 4in exaust and K/N intake.I dynoed a little over 380 hp and 696 on the tq.that was level 4.I also have a 6speed duelly.so mine is a little more setup to plant the power on pavment than a 3/4 ton sport.the sports have the high speed rearend don't they?I have 3.88s in the axles.
Old 07-05-2007, 10:57 PM
Big Blue24's Avatar
You need more turbo like a SPS 62 or a HTT 71 series 62 with a 12cm housing. Then you could add some RV injectors or some cheap jammer's.
Old 07-06-2007, 01:21 PM
smog2001's Avatar
OK, can anyone recomend a good place to purchase.
Old 07-06-2007, 04:34 PM
thellums's Avatar
citydiesel.net seems to have some pretty good prices on Jammers
TDRattler
07-12-2008 07:42 PM
dieselJon
07-22-2007 12:39 AM
robox
10-18-2005 07:38 PM
j
12-21-2003 10:26 AM
Quick Reply: Need more power!
