need more boost?
Old 02-27-2008, 10:26 AM
fmxr47's Avatar
need more boost?
i have done all this performance stuff to my 99 including stage 3 nozzles and a quad chip, is there any thing i can do to my turbo to get more boost and be fine with the stock head gasket and studs?, i know im an idiot cause i dont have gauges but thats the next thing on my list, and i need to finds the cheapest price on gauges if any one can help?
Old 02-27-2008, 11:28 AM
fmxr47's Avatar
can i use a needle valve type controller on my truck, does being an automatic have to do with anything?, sorry i dont know much about turbos other than when i blow a boot i loose a lot of power
Old 02-27-2008, 11:33 AM
busa's Avatar
Well brother first you need to now how much boost you have and then can go from there. I have been pushing 45psi with stock gasket and studs.
Old 02-27-2008, 11:43 AM
scottsjeeprolet's Avatar
You need a boost elbow to get the stock charger up. But it looses efficiency above 35psi, just pumping hot air. Plus it might self destruct at higher levels.
You have got to get gauges!!!!!
Old 02-27-2008, 11:48 AM
fmxr47's Avatar
should i do an elbow or should i do the needle valve?, what are the advantages and disadvantages to each, and which is a simpler mod for my model truck?
Old 02-27-2008, 11:59 AM
98.5Hotrod's Avatar
you should just leave it alone, with the jammer stage3 and the quad you should be in the 30-35 psi range already.
Old 02-27-2008, 12:04 PM
fmxr47's Avatar
i guess ill find out when i get some gauges, thx for the help yall
Old 02-27-2008, 12:05 PM
The stock waste gate pops off at 20psi or so. It's a relief valve of sorts.
Just get the boost elbow, that's the easiest.
Old 02-27-2008, 12:21 PM
Big Blue24's Avatar
Put some vice grips on the black silicone line and see if it helps performance. Vice grips will prevent air from running down the silicone line and opening the bypass wastegate.
Old 02-27-2008, 12:26 PM
Big Blue24's Avatar
Go down to auto zone and buy a cheap, 16 dollar 100 psi oil pressure gauge and see what you have for boost right now. The black ones are 20 and the white ones are 16 complete with nylon tubing and brass compression fittings. If you can't afford that, you cant afford 6 gallons of diesel.
Old 02-27-2008, 12:29 PM
pmtg's Avatar
you dont need more boost unless you have EGT issues...but more boost doesnt necessarily mean more air. chances are you'll be successful in grabbing more air by increasing the amount of boost. but since you convinced yourself you dont need gauges before fuel you have no idea whats going on with your EGTs and have no means of knowing if you need more air.
get gauges.
Old 02-27-2008, 12:47 PM
fmxr47's Avatar
i know i really need gagues, but +$200 doesnt seem resonable to monitor stuff but it is cheaper than having to buy a new engine, i dont drive it too rough cause im worried about frying things but i want to drop my egt's cause im almost positive im right up at 1300 degrees or so
Old 02-27-2008, 12:56 PM
b.lee's Avatar
Until you have gauges there is no way you'll know your EGT's.
Personally running a 24v w/ a chip without a fuel pressure gauges is pure recklessness.
Get the Boost elbow from BD performance.
Its adjustable,
when you get it make sure the adjustment screw is all the way in and install it on the turbo.
It takes less than 5 minutes to install the elbow.
I'd recommend waiting for the truck to cool off first.
Old 02-27-2008, 01:04 PM
HOHN's Avatar
Spoken like a person that doesn't understand just how expensive being cheap can sometimes be.
jmo
Old 02-27-2008, 01:10 PM
fmxr47's Avatar
i have a holley hp150 liftpump i ran w/ bigger lines, fuel pressure is fine, i have had that monitored before, guy lent me a gauge for a week.
Quick Reply: need more boost?
