I need help wiring my "modulite"
Old 06-18-2009, 09:21 PM
Bowser50's Avatar
Exclamation I need help wiring my "modulite"
I can't figure out which wires are which, I pulled the loom back up by the tail lights to figure out where to splice into for my stop/turn/brake lights input and on both sides there is nothing but white/green, white/light green, green/white, and i forget what the last one was I think black. I don't know where to tap in for vehicle input since both sides are the same and for the brake light can I just use one side for the brake or do I have a wire from both sides for that as well? I hope this all make sense and need some help I have used my manual and all it gives me is the same colors that go directly to the wire harness that don't work I don't know where to splice and need some help Fast!
Old 06-19-2009, 12:00 AM
Bowser50's Avatar
okay maybe to clarify a little, I need to splice in up by the plug that plugs into the tail light assembly. I can tell which whire that goes into the assembly is for the stop/turn lights if I know which one is which I can figure it out from there im pretty sure. I traced the wires back hoping to find the seven pin harness spliced into the turn signal wires but I don't think it's that simple and maybe im making it too complicated. any help would be appreciated.
Old 06-19-2009, 10:21 AM
MOAGGIE's Avatar
Try reading over this one, it has pictures and may help you solve your problem, keep us updated because I am having the same issue with mine now.
https://www.dieseltruckresource.com/...light=modulite
Old 06-19-2009, 10:59 AM
Bowser50's Avatar
yeah looked at that one already I got it figured out now I used a multimeter from work and got it all squared away, thanks anyway though.
SOhappy
38
08-20-2015 07:36 AM
kofaram
02-17-2011 12:24 AM
rconkin
07-18-2010 09:32 PM
marktaco
06-01-2010 08:44 PM
greenone
09-08-2009 01:18 PM
Quick Reply: I need help wiring my "modulite"
