Need Help!! Truck wont start!!
Old 05-09-2008, 05:16 PM
commonrailkid04's Avatar
Cranks, wont start, starts on either runs fine, Lift pump went out, replaced it, fills crank case with fuel. Pulled injectors and had then flow tested, was told they had good pattern and no excessive leak back. Whats goin on here, bad flow tube? flow tube to injector leaking? Opinions, suggestions please chime in here! Thanks!
Old 05-09-2008, 06:00 PM
rich's Avatar
when my 03 did thatthe injectors worked other then they were letting fuel back to the tank and not allowing enough pressure to build but they didnt dump fuel. might be a bad flow tube if its still dumping fuel
Old 05-09-2008, 06:06 PM
John Faughn's Avatar
Testing , fuel pressure , codes , power to main pump CP3 ?
Old 05-09-2008, 06:12 PM
did injector kill test, none of them stood out , 8,000psi at idle.
Old 05-09-2008, 10:22 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
Fuel System Test
Procedure to follow to diag fuel system problem
TNDODGE
09-13-2012 01:38 PM
Stroked-Z
10-04-2008 11:28 AM
dieselJon
03-23-2007 10:15 PM
qcstunter
01-09-2007 04:10 PM
Desert Diesel
12-05-2002 08:53 PM
Quick Reply: Need Help!! Truck wont start!!
