need help-tranny service w/band adjustment
Old 11-16-2009, 05:10 PM
p0wd3rp1l0t's Avatar
i plan on doing a fluid/filter change for my tranny comin up here but also want to do the band adjustment and replace the solenoids. from wat i have read i need to buy a governor pressure solenoid and a transducer. i need part numbers for them too so i can order them and also any links or instructions on band adjustment?
Old 11-16-2009, 08:44 PM
DirtEater's Avatar
Do you have a Dodge dealer nearby at all?
Old 11-16-2009, 09:25 PM
annabelle's Avatar
You under warranty?
Old 11-16-2009, 10:14 PM
CoastalDav's Avatar
Part can be bought on line
http://www.transmissionpartsusa.com/...ds_s/10580.htm
Cheaper than Dodge if your out of warranty.
Dave
Old 11-17-2009, 09:43 PM
i am outta warranty and have already purchased the solenoid and transducer(sensor) from that website posted, just was kinda hoping to find a how to step by step instructions...oh and yes i do have a dodge dealer half mile from my shop
Old 11-17-2009, 10:16 PM
CoastalDav's Avatar
There is a DIY thread in this section at the top. Just go back to 3rd Gen 5.9the same section your thread is in and look at the top of the page.
Search band adjustment on this fourm. There is a thread "how to" It would be better to have tranny shop do it. I understand they can be adjusted from the outter part of the tranny.
Dave
Old 11-18-2009, 07:24 AM
92'1stGen's Avatar
Drop the trans pan, change the filter, and refill until it reads full on the stick with the truck running in neutral. Do this every 20k - 25k miles and this will keep the fluid fresh in your trans.
Don't mess with the bands unless you start having shifting issues. If you over adjust them, or don't adjust them properly, than you'll run out of extra adjustment before it's really needed, or you could completely grenade your transmission.
ghstrider87
04-26-2012 06:35 AM
Idaho Guy
12-26-2009 02:18 PM
TX_Diesel
01-23-2009 02:33 PM
Taxidermyman
40
03-17-2008 06:35 PM
betsycam
09-26-2004 03:44 AM
Quick Reply: need help-tranny service w/band adjustment
