need help... too much fuel
Old 01-26-2008, 10:04 AM
Awall's Avatar
Alright I know that with what i've got on the truck (COMP tapped + smarty) is too much fuel for the stock turbo. (I hit about 38-39 psi) I know the phatshaft 62 would be a good choice but I'm limited on $. I have stock injectors and wonder what should be my next move?? Thanks in advance -A.Wall
Old 01-26-2008, 11:42 AM
06RAM2500's Avatar
Should back off on the programmer. At least until you get a turbo.
Old 01-26-2008, 01:13 PM
NoSeeUm's Avatar
Twins and M4's will fix everthing....
Jim
Old 01-26-2008, 01:18 PM
dieselman2300's Avatar
Save for a turbo.
Old 01-26-2008, 01:21 PM
I watch wind blow...
03RAMBUNCTIOUS's Avatar
do i need to worry about exlpoding my turbo, i am making 36-38 psi, egts NEVER over 1150
Old 01-26-2008, 01:26 PM
No, you should be ok.
Old 01-26-2008, 02:38 PM
HOHN's Avatar
YOu might want to check your pyrometer for accuracy. MOst truck with stock turbos pushing 38psi are definitely higher than 1150 degrees, depending on time of year.
IN the dead of winter, 1150 at 38psi is pretty reasonable. But in summer and especially in higher elevations (or both!), that 38psi will often equate to EGTs of 1400 or higher.
JMO
Old 01-26-2008, 04:27 PM
my pyro is mounted where edge told me to, a couple inches above the turbo on the exhaust manifold. one of the local diesel shops around here said "my truck has been horribly denied of fuel" since my lift pump has so many miles on it. he also said i should have no problem getting my egts sky high.
i have planned on putting a new fuel pump system in there and if i cant get my egts up then, i will swap out with a fresh probe and see whats going on.
Old 01-27-2008, 07:20 PM
Awall's Avatar
Jim
Yea thatd be nice... little short on money though. Im trying to get a turbo and save enough to be able to put my winch back on.. think i found a deal though, thanks for the help
Old 01-27-2008, 11:12 PM
powermad's Avatar
get a water methanol kit they only cost around 500 bucks and that will help your egts plenty just dont use too much meth, head gaskets have been known to blow.
dieselJon
01-03-2011 08:18 PM
jmlcolorado
12-16-2009 04:43 AM
jjrightmire1973
11-20-2008 08:20 AM
PourinDiesel
15
06-16-2008 09:51 AM
Camarogenius
19
03-29-2007 10:44 AM
Quick Reply: need help... too much fuel
