Need Help
Old 01-06-2008, 02:47 PM
kencan2's Avatar
Need Help
When you plug in your truck, What is that heater called and can they go out.
Old 01-06-2008, 02:57 PM
rjm022's Avatar
engine block heater- heats your coolant. i am sure they can fail- i would remove it and check the cord for damage,etc. but before you remove it, i would check it up on the engine, to make sure the connection is tight and did not "work" itself loose- if i remember correctly, it screws in. you can remove the whole unit in a matter of minutes.
Old 01-06-2008, 04:27 PM
kencan2's Avatar
thanks for your help
Old 01-06-2008, 04:46 PM
ptgarcia's Avatar
Does it heat the coolant or the block?
Old 01-06-2008, 04:51 PM
kyachovitz's Avatar
It heats the coolant, which basically, heats the block.
Old 01-06-2008, 06:00 PM
rjm022's Avatar
what kyachovitz said.
Old 01-06-2008, 06:24 PM
Gunrunner's Avatar
They DO fail. The original one on my 92 lasted 10 years, changed it out and the new one quit in a month, next one 3 days, next one 5 monthes, next one a year, and last one bout 4 years so far and still good. The first and last one I put in I had to buy cause cummins only warranties them for 1 year.
Old 01-06-2008, 06:40 PM
Rednecktastic's Avatar
Dang, must be cold in Dallas... I don't even know where my block heater cord is or where it plugs in.
smokin24v
03-18-2008 01:21 AM
pwrtripls1
02-08-2008 07:25 PM
spooling
09-13-2007 10:05 PM
coupdetat
01-17-2007 09:23 AM
Quick Reply: Need Help
