Need Help with programmers
Old Sep 11, 2006 | 08:18 PM
2006 MEGACAB's Avatar
I see some people have had problems with the edge attitude and I also read once this is hooked up it will void your warranty because of the peice you have to drill to put on. Is this true?? If it is then I want to know what chip or programmer can I put on my truck that will not void my warranty or something that the dealership can not trace.. I have a new edge attitude that has been sitting on my counter for about 3 weeks now because I dont want to void my warranty. thanks for all your help. Rob
Old Sep 11, 2006 | 08:21 PM
Lrdchaos's Avatar
Just put it on, and when you go in just remove everything but the pyro. Buy your a cheap pyro gauge and if they ask pull it out and tell them U use it when you tow. Or you could always just plug it with a pipe plug. That is what my truck has in it since I removed the commander.
Old Sep 11, 2006 | 08:25 PM
K thanks for the info also what happens if I dont hook the pyro up is it a must do???
Old Sep 11, 2006 | 08:28 PM
973604x4's Avatar
don't put a chip on it if you don't want to void a warranty. that simple. If you want to risk it, install the chip. Its the risk you take.
Old Sep 11, 2006 | 08:55 PM
tdm's Avatar
tdm
2006 MEGACAB,
You could use a box that doesn't damage the wire harness like the Quad Race box. It uses the factory plugs, "plug N play". Nothing for the dealer to see and gives you up to 130 HP. Easy install.
I love mine!
greenworks
Jan 21, 2006 01:58 PM
DieselGoose
Jun 20, 2005 09:08 PM
saint
0
Feb 11, 2005 10:33 PM
hotdram
Jan 31, 2005 06:46 AM
Rocket95
Feb 22, 2004 06:54 PM
