Need help, no "wait to start light" truck not starting
Old 08-20-2006, 09:14 AM
loosendend's Avatar
It's a 1997 3500, custom plate on 3 years now, pyro, trans temp, boost gauge, DTT trans, 4" exhaust.
The truck has been running great but without any warning it shut off at a 4 way stop sign, as if i turned off the key. tried to restart and it would only trank over, if i touch the pedal it hits for a short burst and dead again. I've noticed that it's not showing on the dash the "wait to start light". I'v'e checked all the fuses under the hood, they look good, replaced the two relays on the fire wall that should push up the fuel sht off solnoid. still the same problem, although if i manually hold the fuel sht off noid up by hand and have somone turn the ign. it will start and stop again when I let it go. Also still doesn't show a "wait to start light". I've replaced the fuel sht off noid less than one year ago. Is it possible that it's bad again or is there a relation with the "wait to start light" thats giving me the problem.
Thanks for all responses in advance.
=delbert=
Old 08-20-2006, 09:27 AM
LanceD's Avatar
I would check to see if there is voltage going to the solenoid and if there is, its bad again. maybe look into a manual setup
21dovehunt
10-07-2015 08:35 PM
LanceK
01-31-2007 10:50 AM
loosendend
09-04-2006 12:01 PM
loosendend
08-20-2006 08:49 PM
Quick Reply: Need help, no "wait to start light" truck not starting
