Need Help On Nitrous Install on 03
Old 08-22-2007, 08:36 PM
LaCummins01's Avatar
Question Need Help On Nitrous Install on 03
Can anyone tell me where and what color the wire is that needs to be tapped into on the TPS sensor for the ZEX controller. This is on a 03 2500 Automatic 4x4. Should i put the nozzle in the metal pipe between the turbo and intercooler or intrcooler and intake First time posting and first time on nitrous install too. Thanks for any help.
Old 08-22-2007, 10:37 PM
chrleb1's Avatar
Not sure on the wire, I just put them on a switch. You just have to remember to shut it off.
As for placement, right into intake horn on top (after the intercooler). Face the spray pattern so that it'll spray into the plenum.
Old 08-23-2007, 12:56 AM
jwb600's Avatar
how much nos do you spray to get those numbers?
Old 08-23-2007, 07:09 PM
Update on Nitrous Install
Got everything hooked up and workig correctly today, just waiting to get bottle filled tomorrow. The tps wire that the controller connects to is yellow, tied in right below tps sensor. Its easy if you take the 3 bolts out and flip it over. Put the blue led purge light in the wiper cowl (recessed). Should look cool at night, cant wait Hardest part was finding room for the solenoids But it wasnt bad really.
Old 08-23-2007, 08:53 PM
XLR8R's Avatar
I think you'll find that NO2 will be more effective when injected pre-CAC.
Old 08-24-2007, 11:27 AM
chrleb1's Avatar
When I ran those numbers from May Madness, One of my jets was clogged. So I was running about .065 of NOS.
Old 08-24-2007, 11:30 AM
chrleb1's Avatar
Sometimes that's not true. As it goes though the intercooler, the cold air warms up (causing expansion and hurting the flow). You want it as cold as possible, meaning right into the plenum. This will make the plenum into another intercooler when your on the button.
It is better to have two intercoolers rather than trying to make only one more efficient.
Old 08-25-2007, 09:33 AM
XLR8R's Avatar
It's true every time both places are tested for power; airhorn injection of NO2 cools the intake charge TOO much in comparison, lowering the combustion chamber temps and thus the engine's BSFC.
Mike D
87
04-10-2008 03:18 PM
bskrenn
26
11-28-2007 09:27 PM
Mighty Goat
08-29-2007 09:04 PM
Rpainter
06-24-2007 09:41 AM
kingofdodge7131
12-09-2002 06:12 AM
Quick Reply: Need Help On Nitrous Install on 03
