Need help finding switch
Old Dec 9, 2002 | 09:48 PM
Hauler's Avatar
Well I'm hoping that someone here can help me out as I've been unlucky with truck parts dealers, compressed air dealers ect. What I am looking for is a vacum over 12 volt electric selinoid/switch. I am working on a project for the truck and just can't seem to find what I need. The switch will be used to turn my exhaust brake on and off via using a fuller 18spd shifter which is vacum operated. I have seen this set up and really like the looks of it. The only thing holding me back is the vacum over electric switch. I will run a vacum line to the shifter then runa vacum line to the vacum to electric switch ( should I ever find one) and this will turn the exhaust brake on and off. If anyone knows of a switch like this please let me know. I've been looking for a couple weeks now with no luck. Please leave a reply here or e-mail me at<br>hauler@mindcandies.com<br>Thanks for the help in advance.<br>Derek<br><br>--------------------<br>2002 3500 2WD QC LB<br>HO 6sp 4.10 LS <br>&quot;<br>
Old Dec 9, 2002 | 09:53 PM
danlit's Avatar
Re:Need help finding switch
I have one on our 61 ****** Jeep to work the wipers<br> Danny
Old Dec 9, 2002 | 10:07 PM
popnjon's Avatar
Try a Buick dealer and ask for an EVAP purge solonoid or valve for a 2000 Lesabre. It is used to purge fumes from the tank and uses engine vacumb and 12 volts to open when needed. Don't think it is a PWM switch but you may want to check with one of their techs. Good luck, Warren
Old Dec 12, 2002 | 10:48 PM
Tom Bolitho's Avatar
Hauler<br> If you want a switch like an oil pressure sender try Cole-Hersee. Their 92077 is normally open closes 7&quot;-13&quot; vacuum<br>the 9253 is normally closed opens 9&quot;-12&quot; vacuum. You can get them at almost any heavy duty auto electric shop.<br>tom
Stevenc
Oct 17, 2003 10:20 AM
ramguy
May 27, 2003 10:48 AM
Skyking650
Feb 9, 2003 06:40 PM
Skyking650
Jan 11, 2003 11:02 AM
