Need help with codes.
Old Mar 24, 2006 | 05:21 PM
Dazed&Confused's Avatar
Ok truck acted a little funny this week so I ran the onboard check and got these codes, anybody tell me what they are? I think my IP may be on its way out. When I floor it I get a stutter.
P 0500
P 1693
P 0522
Andy
Old Mar 25, 2006 | 02:57 PM
ib516's Avatar
towrig.com has a complete list of codes in the Dodge Cummins section
Old Mar 25, 2006 | 05:38 PM
Thank you very much!
Andy
Old Mar 25, 2006 | 06:16 PM
graphitecumnz's Avatar
P0500... no vehicle speed sensor. I usually set that code by spinning the tires.
P0522... oil pressure circuit low. Have you witnessed low oil pressure??
P1693... companion code alerting you to the other codes.
a stutter could be many things but the codes are pointing to other things and not a failed VP-44. Assuming you used the "key trick", all codes may or may not show up with that method.
Old Mar 26, 2006 | 09:06 AM
Well I did do a big burnout the other nite so I bet that is were the one came from, as for the low oil preasure it has not droped off from were it has always been.
Andy
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
Sam Turner2
Jan 11, 2008 03:32 PM
mbenedict
Jul 21, 2007 09:19 PM
