Need help with code
Old Sep 18, 2007 | 10:33 PM
jpajax's Avatar
Question Need help with code
Put the switch on the tc to lock it manually. Work great but when I check it for a code by turning the switch on an off three times p0700 will come up then go away and pdone will stay on. What is going on.
Old Sep 18, 2007 | 11:38 PM
vzdude's Avatar
DTR's 'Go to Guy'
Computer is seeing a problem. Did you put the resistor in? Or did you do it at idle? Could have caused the codes. Looking to put that in mine this weekend too!
Old Sep 19, 2007 | 08:31 AM
jpajax's Avatar
No I didn't put the resistor in . Don't know what you mean by idling in park.
Old Sep 19, 2007 | 09:56 AM
vzdude's Avatar
DTR's 'Go to Guy'
Did you flip the switch any time other than driving down the road?
Old Sep 19, 2007 | 05:33 PM
jpajax's Avatar
No it was after 40mph. went and had code removed at dealership and ask what the code was after looking on DC sight the only thing that came up was lack of power and suggested that an up date program be done. On the way back home stop several times not using switch no code then used switch got code p0700 again. Put a 33k ohm 1/2 watt 5* tolerance resistor in ground wire and left jumper in relay and it didn't work at all. Will it hurt truck if the code stays and still use switch because I really like the options the switch provides.
Old Sep 19, 2007 | 06:22 PM
jpajax's Avatar
OOPS just did search on tc switch on this forum and I used wrong resistor it needs to be 33ohm not 33k ohm I guess I had a senior moment. Still would like to know about the code if it will hurt to continue run truck with it. Will try using resistor and no jumper on relay if someone has already try ed this on 03 48re let us know.
Old Sep 20, 2007 | 07:31 PM
jpajax's Avatar
Well it works without jumper just resistor
coope3
Feb 21, 2009 04:49 PM
kenny1987
Jan 24, 2008 01:19 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
