Need help with 0336 code, Crank sensor cct
Old Jan 17, 2009 | 02:02 AM
cLAYH's Avatar
So about a week ago the truck started to miss occasionaly when driving it hard. Then it started missing at all the time and now it does it at idle. Pull the codes and I get an 0336 code, crank sensor cct.
I've replaced the crank sensor with a new one and checked the wiring going around the AC pump and its good and in a loom. I've also disconnected the Edge to to be sure.
Any other suggestions?
Old Jan 17, 2009 | 10:20 AM
cLAYH's Avatar
Looking at the wiring flow chart the AC transducer and map sensor are on the same 5V source. Anyone ever have one of those fail and screwup the CKP?
Old Jan 17, 2009 | 06:16 PM
cLAYH's Avatar
OK I figured it out, the bolts that hold the harmonic balancer onto the crank came loose, one was missing altogether. This allowed the tone wheel behind it to be loose and was causing the erratic crank sensor reading.
I've read that the holes in the tone wheel can be elongated and indexed to adavanced timing. Whats the advantages of this and which way does the tone wheel need to be turned to do this? My holes are elongated a bit from the bolts being loose already.
geno_86ed
Mar 19, 2010 02:52 PM
Timberman
Jan 20, 2008 07:44 PM
sluggo42
Apr 22, 2007 01:19 PM
03CumminZ4X4
Feb 27, 2006 01:37 PM
NaplesNole
Jan 17, 2006 09:21 AM
