Need Edge Help 0013, 0237, 0069 A2 doesn't show info...
Installed Edge Juice & A2 tonight...
A2 powers up, gps works, but start the truck and it doesn't show anything; egt's, boost, temp, rpm, all 0...
Throwing the following codes 0013, 0237, 0069...
I think one of those is probably from unplugging the map sensor connector while the truck was running...
Check engine light is also on...
It's getting power (checked the fuse)
Any Ideas???
Any Ideas???
Try with truck off disconect plug ins leave disconected for a minute reconnect everything. Then check your fuse connection. My direcions gave the wrong fuse to hook to. If your fuse box is the same as an 2005 I ran the wire for the edge box to #37 fuse and for the one that goes into the cab I used #41 fuse. Everything has been working for 1 1/2-2 years.
Pulling any of the connectors when the engine is running is not a great thing to do and yes that will throw codes. Follow the instructions from edge to clear the codes.
Disconnect power and recheck ALL connectors. You will most likely find one is loose or connected backwards.
How can I clear the codes using the A2...? I can't find anything in the Juice or A2 books on clearing codes...
You should find the Retrieve and Clear codes menu on the A2 setup screen. (at least that is where it is on the Attitude).
I might be wrong but I don't think you can do that with an A2... I hope I'm wrong... If they can't be cleared with the A2 how do I go about clearing them?
I believe the Juice and the A2 are not playing well together...
Disconnected the A2 and hooked up the Edge 3 position toggle switch and the Juice seems to work. Going to get a hold of Edge on Monday...
twotirefire
01-16-2008 12:44 PM
