Need Ecentric washer & Bolt for alignment
Old Dec 11, 2006 | 09:21 PM
Tommy93w350's Avatar
The ecentric washer that adjusts the caster on the trailing arms is stripped inside. I can turn the bolt and one side turns normal but the other side sits still.
What would be a part # and the best place to buy?
Old Dec 12, 2006 | 07:54 PM
Come on guys, It's the lower control arm cam bolt and washer that controls the caster adjustment.
This bolt has been a pain to keep the alignment correct.
Old Dec 13, 2006 | 07:27 PM
deezl's Avatar
I put the lift on my ctd and had to take a sawzall and cut my bolts off. got new ones and the local mopar garage. cost about $70 bucks for both
Old Dec 13, 2006 | 09:19 PM
I pulled the bolt and washer out today, the bolt has a flat side on the shaft and the washer hole matches the bolt. When the bolt turns, it turns the eccentric washer and changes the degree of the caster. Mine, the bolt and washer rounded, this allowed the bolt to turn and washer never moves.
The Dodge dealer that's usually high on their parts can order the bolt and washer, for $9.00 a piece. Not bad, $27 for one bolt and two washers. I don't have the part numbers with me right, but I'll post them tomorrow for everybody.
DuMont
Oct 22, 2012 07:50 AM
dodgethis91cmns
Jan 16, 2008 07:37 PM
KRB
Nov 27, 2007 04:32 PM
8mpg
Jun 15, 2007 07:38 PM
jlells01
Feb 14, 2003 12:58 AM
