Need an answer QUICK!
Old Sep 19, 2005 | 09:15 PM
blackdiesel's Avatar
Registered
ok, so the pulls are tomorrow and ive herd that ill have to pull a dual. Will this be better? if so, outside or inside? Need an answer as soon as possible! Thanks alot!
Old Sep 20, 2005 | 07:25 AM
24valvepuller's Avatar
I would leave the inside on and pull the outside one
Old Sep 20, 2005 | 07:59 AM
Registered
OK Thanks alot. but if i can leave the duals on, would it pull better?
Old Sep 20, 2005 | 09:00 AM
PourinDiesel's Avatar
Leave the dual wheels on.
Old Sep 20, 2005 | 10:41 AM
Registered
So duals would be better?? ive herd leave em on and take em off. I can see how both have their better sides.
Old Sep 20, 2005 | 11:02 AM
Yeah, I think there better. There are times I definitely would have pulled better or could have used the traction from dually wheels.
Old Sep 20, 2005 | 09:12 PM
cumminsdriver635's Avatar
Leave them on! Duallys always seem to me like they pull better than single wheels.
Eric
Old Sep 21, 2005 | 08:01 AM
Registered
lol pulls were last night. i took the outside dual off but now i realize i shoulda left em on. So if ya pull with a dually, LEAVE THE DUALLS ON. or even better yet, get a single heavy lug tire. like im going to do.......
Old Sep 21, 2005 | 12:48 PM
JoshPeters's Avatar
Careful with that. I have aggressive M/S Tires for my dually....you'd best be able to spin them. If you can't...your aggressive single can get you the same place it got me.....Broken parts!
Josh
Old Sep 21, 2005 | 01:31 PM
Buckshotmckee's Avatar
So how did you do?
Old Sep 21, 2005 | 04:33 PM
JoshPeters's Avatar
I went 248 before the front driveshaft let go. If you go with the aggressive tires....you had better have LOTS of power to turn them. I dont' know if you made it down to IRP this year, but even the big boys had problems running the aggressive tires on that track! I'm seriously thinknig about getting another set of wheels and tires with an A/T type tread (Yokohama Geolander A/T's maybe) for tracks like that. The MT's (Kuhmo Venture M/T) will work great on loose tracks, but there are times when the aggressive tires will get you trouble!
Josh
Old Sep 21, 2005 | 04:47 PM
Asher's Avatar
What would happen if you aired down one set and kept one set up??? Maybe like 60 PSI in the inners and 25 PSI in the outers??? This would make the inside ones work real hard and have a higher pressure contact patch, but when they started to loose traction the lower pressure tires would help extend the contact patch and might pull you alittle further????
I don't know, I don't own a duelly.... but it would be a neat exeperiment and if it worked... then a great secret.
If I had pull a set, to guess I would pull the inside tires since the outside ones would be running on fresh ground instead of trailing in the loose tracks the front tires just created...
Old Sep 21, 2005 | 07:40 PM
Registered
buck shot: didtn do so good. but i didnt break anything
josh: i had no problems getting wheel spin. but a real aggressive tire might be a different story
Asher: i dunno and i probly wont ever know because im gettin a set of pullin tires on different rims
Old Sep 21, 2005 | 10:14 PM
djgaston's Avatar
What tires are you going to get?
Old Sep 22, 2005 | 08:02 AM
Registered
im goin down to tire world and im gunna pick up some take-offs that are aggressive enough, however not to aggressive to break something really easly. we'll see how it goes
