PDA
View Full Version : NAPA Gold Filters OK?
ValkSmile
03-19-2007, 07:04 AM
Are the NAPA Gold filters OK to use in the CTD? I noticed that the NAPA filter only has 6 holes around the top, where the Mopar filter has 8.
I know that Fleetguard is Ok to use, anyone know how many holes the Fleetguard has around it. Are there any stores that carry Fleetguard locally?
Scott
surfram
03-19-2007, 08:17 AM
I am currently running Napa Gold (Wix) Air/Fuel/Oil filters from fleetfilter.com. No problems and great MPG combined with Rotella 5-40 synthetic.
TRC51
03-19-2007, 08:44 AM
I am using the Napa Gold as well. Was actually recommended on this site for better mileage and great perfromance, so I went with it. No regrets. I believe someone posted that it carries the same flow rate or better that a K&N does. Either way... I'm happy with it.
1qckdodge
03-19-2007, 09:10 AM
Napa has a updated filter that I just started running, ill get the part # when I go outside, I have however been running Napa Gold on all of my vehicles for the last 3 years, no issues what so ever.:cool:
PourinDiesel
03-19-2007, 10:19 AM
The fleetguard (Cummins filtration) oil filter is equipped to flow more volume than the napa gold. (someone get the picture!)
rsegall
03-19-2007, 10:37 AM
I'm about 99.9% that the NAPA Gold 5760XE is a Stratapore re-paint. Totally different that the regular 5760. Unless you buy from an internet retailer, you can get the Stratapore LF16035 much cheaper.
PourinDiesel
03-19-2007, 10:41 AM
Napa's are all made by Affinia the company that makes WIX.
R6Luver
03-19-2007, 04:25 PM
For you guys with AAA, you get a discount at NAPA, just a heads up!
PEAKSTRYDE
03-20-2007, 10:17 AM
I have only used NAPA filters since the trucks 1st oil change!!!!!!!!!!!!!!!!!!
Guess we really won't know if there is an issue for a couple hundred thousand miles.
PourinDiesel
03-21-2007, 02:22 AM
The Napa/Wix/Affinia's are probably just fine to use. But if you want to use a better filter I suggest a Fleetguard.
1qckdodge
03-21-2007, 06:24 AM
Here is some info I found out about the 7620xe
http://s94998462.onlinehome.us/cummins.html scroll down a bit
http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=FIL&PartNumber=7620XE&Description=Oil+Filter+(Gold)
Hairy1
03-22-2007, 07:40 PM
Fleetgaurd is avalible from any Cummins shop or usually heavy equipment dealer
LongRanger
03-23-2007, 01:20 PM
I checked out a 7620XE at the local NAPA. Has eight holes around the top, for whatever difference it may make, and has the Wix name stamped on it, Made in USA. Looks like a quality filter. They want $16.49 for it plus tax. If you run a search on the third gen 5.9 forum you will come up with more info on oil filters than you care to know.
It's really hard to beat Geno's garage and Fleetguard Stratapore for price, quality, and convenience. I think the problem most people have with getting a Fleetguard is that they are hard to find locally, or at least not as convenient as a NAPA.
doug60
03-24-2007, 11:17 AM
Wix / Napa / Fleetguard 57620XE / 7620XE / LF16035
They are one in the same. Made by who ???
Industry secret.
PEAKSTRYDE
03-24-2007, 01:55 PM
WOW [nonono] [nonono] [nonono]
Search on Ebay, I bought a whole case for about $75 thats $6 a filter.http://www.smileyx.com/smilies/jumping0002.gif
