name this leak...
Old 04-24-2007, 10:55 AM
avengermike's Avatar
name this leak...
im new to cummins and would like any help thank u.....
its on a 96' drw 12v, i did have some oil build up but after towin a 11k fifth wheel from texas, it now blows oil all over belt and pass front wheel area. even now with out trailer it still does it. the truck had 171k when i bought it and it now has 173k. but like i said didnt start blowin oil till i pulled that trailer. thinkin that the stress on the truck towin broke threw the build up and now i have a leak.
Attached Thumbnails name this leak...-p1010174.jpg   name this leak...-p1010175.jpg   name this leak...-p1010176.jpg
Old 04-24-2007, 12:29 PM
clutch1's Avatar
hard to tell exactly where its coming from clean it and run it. could be cover leaking, front seal leaking, or might be a pin failure.
Old 04-24-2007, 02:18 PM
10-4 will do, ill get new pics up after
Old 04-25-2007, 08:52 AM
T-Bone's Avatar
After you clean it, check the timing cover bolts. I thought I needed to do a front main seal and it turned out all I had was a loose bolt on the timing cover.
T-Bone
Old 04-25-2007, 12:01 PM
MNorby's Avatar
kinda looks like mine. That top brightest bolt just to the left of your oil fill in your pic was loose on mine.... not just loose, about to fall out. That and my oil fill was all wet around the base so took some channel locks and got about a 1/4 turn on it. I haven't drivin yet to see though. I was messing around with it at 1: this am.
Old 04-25-2007, 12:39 PM
thanks all for the info. clutch1, if the pin has come out whats the fix/damage? nmorby, my filler tube was lose i could move the plastic washer, just hard to get a good turn in their. i just washed it the best i could ill keep an eye on it.
Old 04-25-2007, 01:04 PM
Need95-00CTD's Avatar
Looks exactly like my pin failure about 2 months ago... Get a buddy and 2 cases of beer, and a weekend free to fix it. Your pulling everything off the front of that truck all the way to the cam...
Old 04-25-2007, 04:11 PM
is their a link to how to tear down the truck so I can fix and is their a replace kit I need to order?
Old 04-25-2007, 06:58 PM
infidel's Avatar
http://cumminsdatabase.com/read.php?id=111
Old 04-25-2007, 07:00 PM
clutch1's Avatar
there is a link somewhere in the forums. hope its not the pin failure. go ahead and pull the front cover to look, if its there you'll need to tab it then you can seal the front cover and put a new front seal in.
Old 04-26-2007, 08:34 AM
and if the pin is not their? what is the pin for? sorry newby
Old 04-26-2007, 10:10 AM
infidel's Avatar
Then you need to replace the pin and repair any damage it caused coming out. The pin is there to keep the case aligned and is essential. There are actually two of them but only one has the tendency to come out.
Old 04-26-2007, 10:40 AM
DTR question asker
dieselfuelonly's Avatar
Where is the other one at?
Old 04-26-2007, 10:08 PM
Jeremy Cusick's Avatar
the passenger side one is the one that walks out... the other one is on the driver's side.
Old 04-29-2007, 11:52 PM
k update i noticed a little oil looks like its comin from behind the water pulley and from the oil filler
grandpa ralph
06-05-2008 04:16 AM
grandpa ralph
04-23-2008 08:13 PM
Stamey
12-23-2002 10:14 PM
NWDave
11-07-2002 10:12 AM
Quick Reply: name this leak...
