my rear window leaks
Old 12-05-2006, 11:43 AM
lews930's Avatar
I took the carpet out and ran a hose over the roof (actually a friend did it) as the hose was running I ssaw water running down both sides directly under the area of the roof channels. I have a sliding rear glass.
Is the seal on these replaceable? Or should I look more at the 3rd brake light aS THE PROBLEM?
THANKS AS ALWAYS
LEWIS
Old 12-05-2006, 01:11 PM
crazylunker's Avatar
before you go pull the window look reeeeaaalll close at the 3rd brakelight. I thought the same as you till a closer inspection showed the light leaking into the headliner and traveling to the sides of the window, I installed a brand new from chrysler light and that one leaked. I finally siliconed the brand new light and there hasn't been a drop in over 2 years.
Old 12-08-2006, 04:13 PM
lews930's Avatar
You are correct crazy lunker. I had anothe friend put the hose water on both sieds of the window and no leaks. He then put it directly on the 3rd brake light and the water came in and ran down both sides under the ends of the glass. wow.
Got my new seal today.
thanks
lewis
Old 12-10-2006, 12:48 AM
snowrodeo's Avatar
i had the same prob. 3rd light leakage. pulled the light off, spread some silicone around the old seal, no more leaks in last two years.
DragonSlayer
19
09-30-2012 08:41 PM
abchoppers
01-26-2011 05:38 AM
Wolfcsm
03-01-2010 06:44 PM
xzaq103
04-28-2008 01:09 PM
raven392003
10-29-2007 11:39 AM
Quick Reply: my rear window leaks
