My First Carnage
madhat's monkey boy...
My First Carnage
I had my first expensive breakage this weekend. The tensioner broke in half. I have been in a diesel shop for 10 years now and never seen a tensioner break like this one. The pulley chunk took out the fan / radiator / shroud / belt.
I was racing my friends D-Max when it let loose. (I did win by the way )
He is pretty cool, he gave me his truck for a couple of days until I get the parts to fix mine.
I am trying to figure out how it broke the way it did. All the pulleys are good and aligned. CTD's really suck when you loose power steering and brakes. I could see it causing a bad accident if a belt broke and cars in front of you.
I was going about 85+ when I had him by 4 truck lengths. I went to hit the brakes and I felt like ol' Al Bundy..... No brakes....No brakes!
We had a pack of diesels that night. 2 05 CTDs, 01 CTD, 02 CTD, and 01 D-Max we were all heading to the ski slope to ride tubes down the mountain.
I was thinking about that the other day. If we loose or belt we loose our brakes. Sort of a risky situation.
Glad things worked out for you. Parts are fixable, lives aren't.
I cannot believe they dont make these things with an emergency electric booster like the GMC 5500/6500's have. It could have been REALLY bad, no brakes or steering.
Try turning of your engine in neutral next time you are driving and see for yourself how bad it is.
yep mine did yhe same thing, i was lucky got home from a fishing tip and let loose backing my trailer in. what a p.o.s it was like 260 bucks from the dealer and wasnt covered.
3947574 Display part line detail
TENSIONER,BELT $56.31 $56.31 Show part supersession Delete part line
That is the cost of the tensioner from Cummins. How can the dealer mark up the part that much????
With age comes the cage
Have you installed the over running alternator pulley..it eliminates belt chirp at shut down which causes belt wear and/or shred...it may have led to the pulley breaking as well ..Link to TSB:
http://dodgeram.info/tsb/2006/09-004-06.htm
The Overrunning alternator pulley should have been a recall but Dodge would rather you and I drive a dangerous truck..
I dont like the way the tensioner broke and the new one looks identical to the old one. I dont feel real good about it.
FWIW, my tensioner broke as well, but was a result of the Jacob's vacuum pump locking up, and the belt melting till it snapped.
--Eric
tcr
12-04-2004 01:51 AM
Gypsyman
18
10-02-2004 11:59 PM
