My Buddy's 47re acting up.
Old 10-12-2005, 01:23 PM
Palmetto_kid's Avatar
Truck: 2001, 2500, 4x4, automatic. 139k miles.
Here is what it's doing. After shift into drive, the rpm's go to 2500 before it will shift to 2nd. It doesnt matter how easy, or hard you are on the foot pedal either. Neither of us know much about automatic trannys, so I figure I would ask you guys.
He said that he had the tranny filter changed, and that helped for a little while, but now its acting up again.
Thanks!
Phillip
Old 10-12-2005, 01:48 PM
dieselrob's Avatar
Theres a throtle positoin cable that goes into it just buy the shift linkage. check to make shure that is all hooked up right. My spring broke on mine and it was shifting funny for a while till i found the problem .
Old 10-12-2005, 05:19 PM
BigBlue's Avatar
Did you try the APPS reset?
Old 10-12-2005, 08:55 PM
mamm7215's Avatar
Check for codes...key on/off 3 times read odometer. Mine was shifting longer from 2 to 3 and 3 to overdrive and I threw a P0720 - output shaft sensor out of range. Replaced sensor (located on overdrive unit on back of tranny) and shifting problem went away.
Old 10-13-2005, 01:29 AM
J BODY's Avatar
Would also be nice to monitor the gov psi sensor with a scan tool.
GPSflyer
29
10-03-2022 06:41 PM
samgovol
09-25-2007 10:07 PM
Munchies
10-19-2006 06:09 AM
97-12v
12-27-2005 10:09 PM
w4xtc
05-13-2003 08:39 PM
Quick Reply: My Buddy's 47re acting up.
