View Full Version : My 89 Is sooo quiet
Bogurt
02-28-2009, 11:25 PM
My 89 d250 is practically silent compared to the truck in my signature. Im not talking about exhaust noise either. Is this normal? Its an awesome truck for 400 dollars. I got my column together and working. The only thing i need is new upholstery and the shifter parts. unfortunately, i found a dead rat under the seat. it managed to eat away a good bit of stuff. My truck has what appears to be a factory high idle control on the pedal, a different throttle bracket, and a different vacuum pump among other things.
sdstriper
02-28-2009, 11:48 PM
Oh yah, these trucks will even kill the rat thats eating on them! [laugh]
The hand throttle huh. Cool. Let me know if you want to give that away... Keep your eyes peeled for the newer style vacuum pump, cheaper and better upgrade than fixing them if they crap on you.
peobryant
03-01-2009, 03:43 AM
Is it just at idle? I know Non I/C trucks are timed differently from the factory, that might have something to do with it.
Or maybe, you're just crazy... [laugh]
wannadiesel
03-01-2009, 07:00 AM
It's probably timed stock, and the valve lash might be a little tight. Makes 'em real quiet.
I like the old style vacuum pumps, they work pretty well even if you lose one diaphragm. Jim Lane wrote a nice "how-to" on working on them, it's in the sticky.
Paint it with black primer, leave the upholstery, make a shifter out of rebar and an 8 ball, and call it a "rat rod". [laugh]
guitarman
03-01-2009, 10:23 AM
Although mine doesn't have one, my owners manual shows the hand throttle.
in the diesel suppliment, for warmup only.
Crossy's son
03-01-2009, 10:27 AM
Werd on everything he said,
The vac. pump on our 91 quit and it just had bad brakes until it was warmed uop, not too hard to live with my dad said, my mom hated it though [laugh]
the rebar shifter would be swweeeeeet. :D
Bogurt
03-01-2009, 11:32 AM
im actually toying with doing a rat fink lime green with pink flames scheme. it is timed stock and is quiet at any rpm. the factory stereo in this truck is also way better than mine.
Crossy's son
03-01-2009, 12:56 PM
flat black truck (roll on :D) with red rims... :)
Oh my gosh that would be sooo cool. and old school
If your not gonna tow with it, cut the front coils down and remove some rear leaves and make it lower like SkinnyBTN's truck.
Your so lucky, :( $400
Exekiel69
03-01-2009, 01:02 PM
If You want it to wake up the hole neighborhood put a straight pipe in it, it will sound like a tank or semi coming down the road. Mine sure does.
Richie O
03-01-2009, 02:02 PM
Thats not an 89 in the pic unless stuff was changed.
Bogurt
03-01-2009, 02:32 PM
it was in a collision. it also has an intercooler now. i already have a loud truck.. maybe ill make this one into the stealth machine.
peobryant
03-01-2009, 03:31 PM
I think you should go the hood stack route. [coffee]
Bogurt
03-01-2009, 04:12 PM
Im in california, hood stacks arent tolerated. I have a stack already with my camper shell on my daily driver.
