Multi Function Switch
Old 01-10-2007, 02:14 AM
Tsutter's Avatar
Anybody know where to get a new Multi Function switch (the turn signal dimmer) besides the dealer. My buddy needs one for his 1997 dodge 1500.
Old 01-10-2007, 09:57 AM
infidel's Avatar
Have you tried an autoparts store?
Old 01-16-2007, 08:27 PM
dhvaughan's Avatar
autozone. $42.
Old 01-18-2007, 07:57 AM
mcoleman's Avatar
Yep, Bought mine at Oreilly's. You'll also need the torx bits with the hole in them. I already had a set. can't remember the name at the moment but a standard torx won't work.
Old 01-18-2007, 05:53 PM
sixguns's Avatar
tamper proof torx
Old 01-19-2007, 07:26 PM
dhvaughan's Avatar
Originally Posted by sixguns
tamper proof torx
autozone $9 for a kit of various sizes including the one you need.
the screws you will take out are VERY long, and your wrench space is tight, and it takes a long time to get them out. replace them with either regular torx or allen head. you will need 2 or 3, i think 4mm, about 3/4 - 1 inch long.
TIP.. while you are there, if you want to disable the door open/key in switch dinging, unplug the little 2 wire connector to the ignition switch.
BIG MEX
05-22-2010 10:56 PM
Ram of Steel
09-16-2009 06:30 PM
smokeyram
08-21-2009 06:19 PM
smokeyram
12-16-2008 07:35 PM
CanuckCTD
09-25-2007 06:44 PM
Quick Reply: Multi Function Switch
