How Much Tranny Fluid Will It Take
Old 12-16-2011, 09:02 AM
flyingd's Avatar
I am changing my tranny filter and will replace whatever tranny oil I lose with new in the process. Since I am not measuring what I lose, how much will I have to put in for a normal filter change?
Old 12-16-2011, 10:26 AM
infidel's Avatar
It depends on how long it's been since the truck has moved until you drop the pan.
Takes a while for more and more ATF to drain back into the pan.
What I do is park close by the shop overnight so I don't have to deal with hot fluid then drive just a few feet to drop the pan.
Takes 4-5 quarts.
If I would have dropped the pan after it sat all night without running it would take closer to 10 quarts.
I always measure how much fluid I drain, makes it so much easier to get the level back where it belongs.
Old 12-16-2011, 05:01 PM
Dr. Evil's Avatar
www.dodgeram.org has all the info you need regarding fluid capacities
Old 12-16-2011, 09:54 PM
joem's Avatar
yup, one gallon if dropped after shutdown for filter change.
phatboy
11-23-2008 11:18 AM
Shank
09-25-2006 10:17 PM
cLAYH
08-23-2006 08:32 PM
RobG
08-18-2005 01:22 PM
CTD2001
13
04-25-2004 06:35 PM
Quick Reply: How Much Tranny Fluid Will It Take
