How much PSI in airbags?
Old 09-19-2009, 10:21 AM
Txwelder's Avatar
Is there a standard amount of PSI that folks are running in airbags in regards to weight of the trailer or is it just whatever gets the truck and trailer leveled out? Thanks.
Old 09-19-2009, 10:28 AM
Boris-MC1's Avatar
I use enogh to level the truck and trailer.
Semper Fi
Old 09-19-2009, 11:14 AM
DTR's Toad Wrangler
Clayten's Avatar
The max is 100 psi. The most I have ever put is 75.
Old 09-19-2009, 12:15 PM
TonyB's Avatar
Most have a min of 5psi...keeps the bag from sagging where it shouldn't.
Most pressure I use is 60-70psi. Levels the truck out and keeps the suspension off the bump stops.
Tony
Old 09-20-2009, 10:05 AM
Jaxom's Avatar
TIMES 22222222222222222222222222222
I run about 60 when towing the Willie Wagon. About 7-8 if empty so I con't have to worry about gauge accuracy.
Old 09-21-2009, 09:12 PM
parklane's Avatar
Don't know if this is the proper way, but, I find highth of rear bumper, hook up 5er, and bring back to same highth. On mine it's 40#.
Old 09-22-2009, 12:23 AM
CD in NM's Avatar
I run right at 10 empty and do the bumper height method like parklane.
CD
Old 09-22-2009, 01:58 PM
eastmentCTD600's Avatar
With my slide-in camper its beneficial to add enough air to help the suspension but not completely unload the leaf springs (typically 25 - 30 psi for my camper); partial load on the springs helps maintain vehicle stability.
Old 09-22-2009, 07:00 PM
lawdog800's Avatar
After much tests, I have learned to set mine to 47 psi....Lower is ok, but less side to side sway wih the 47.
Old 09-23-2009, 09:58 PM
wazz_zup's Avatar
Looks like your getting hits from all over the board!
I run 20 to 25 lbs in mine. That keeps the truck level with the el grande 5ver.
Old 09-23-2009, 10:10 PM
Txwelder's Avatar
I just got done loading my 22ft enclosed with all my worldly posessions. 95 psi barely got her level.
Old 09-27-2009, 01:49 PM
KHJ Transport's Avatar
We use an 06 3500 series with the firestone airbag system,
Pulling a 40ft gooseneck flatbed, hauling up to 20k pounds,
keeping the psi at about 30psi seems to work the best for the smoothest ride.
Old 09-29-2009, 07:20 PM
mcbus's Avatar
Firestones and pulling a heavy 5th wheel. 27 to 30lbs.
Old 09-30-2009, 05:13 AM
HMX-1's Avatar
I've got the Firestone airbags on my truck. I run them about 25 PSI empty and 75 to 80 when I'm pulling my RV/toyhauler, a 26 foot Keystone.
Rides great either empty or loaded with these bags. This by far is the best upgrade I've done.
Kris
Old 09-30-2009, 05:37 AM
Jim Lane's Avatar
I have Firestone Ride-Rite Air Bags on my truck and unless I am carrying something heavy I keep around 10 PSI in them.
They were all part of an attempt to get a better ride but after I reworked my springs I don’t really use them.
The Firestone convoluted bags have an internal bumper built in so if they were run empty they will not be damaged.
I was told for every 1 PSI of air they would lift 10# of weight.
Jim
38 Cigarette
16
08-28-2015 11:27 PM
nrussell
07-23-2008 08:58 PM
Tommy93w350
08-07-2007 12:15 PM
Dave88LX
15
09-04-2006 09:30 PM
ckennedy
09-29-2004 05:06 PM
Quick Reply: How much PSI in airbags?
