how much pressure @ the rail
Old 01-28-2008, 11:35 AM
O.T
O.T's Avatar
running the Dr P 2018 pressure box--110hp progressive. Pressure comes on with minimal boost.
My rail gauge maxes out at 25-26k, this in relation to the sensor max parameters.
Without the pressure box the rail is 23-25k depending on load.
Is there a aftermarket pressure sensor to read higher than the factory sensor?
I cannot call Dr P from Canada. Does anyone know what the actual max pressure would be?
onetun
Old 01-28-2008, 12:10 PM
53 willys's Avatar
I hit 27,700...with my X2 reading off the stock sensor......give or take 100psi..so I know it will go at least that high.
Old 01-28-2008, 03:42 PM
bluechrome's Avatar
I thought the pressure relief vavle was supposed to go off at 27,500
Old 01-28-2008, 03:43 PM
06CTDforAU's Avatar
Me too. I guess it doesn't though??
Old 01-28-2008, 04:28 PM
O.T
O.T's Avatar
Only if you have one!
My rail is capped
Old 01-28-2008, 05:31 PM
omaharam's Avatar
onetun
John at Floor It had a custom one made that manually reads the actual pressure up to 35k. He paid like $1500 to have it make though.
Old 01-28-2008, 07:17 PM
CG98x's Avatar
I think qzilla said the stocker could read 28600, I've never seen that but I have seen 27500.
Old 01-28-2008, 08:00 PM
mike moore's Avatar
according to the shop manual an 07 says around 23,200 stock.
Old 01-28-2008, 09:08 PM
bluechrome's Avatar
I've only been to 27,000
Old 01-28-2008, 09:21 PM
bigjohn04's Avatar
I had the Dr. P 2018 box and Quad RP gauge, it would max out around 26750 at WOT.
Old 01-28-2008, 09:48 PM
Megaramasaur's Avatar
Anyone have the write up to cap the relief valve?
Old 01-28-2008, 11:13 PM
53 willys's Avatar
apparently not..... my commander recored over 27,500 multiply times......
Old 01-29-2008, 12:46 AM
O.T
O.T's Avatar
OK guys thanks....however my point is still in question.
I run dual pumps, with a pressure box I can bury the needle on the rail gauge with zero fluctuation. Perhaps my pressure is 35k who knows.
Since the rail sensor reads max @ 27500-28000 I will never know.
Anyone know how much pressure Dr P adds....3k-5k-6k-7k-15k
onetun
LooseBoltsRob
33
02-07-2010 12:43 PM
incognyto
11-22-2008 01:27 PM
SMOKIN-U
13
09-09-2008 06:58 PM
5.9Excursion
03-13-2008 10:56 AM
DMS1707
04-09-2007 10:31 PM
Quick Reply: how much pressure @ the rail
