to much fuel?
Old 07-22-2009, 11:51 AM
carte89's Avatar
to much fuel?
How much fuel is to much? At what punt do you have to worry about washing out the cylinders? Or is this not an issue pertaining to diesel engines
Old 07-22-2009, 12:30 PM
gus's 03's Avatar
when your not burning it, its to much.
if your not maintaining rail presure, you got to much duration
if your not maintaining rail presure your looseing hp
if your blowing black smoke your not burning it
if your not burning it your loosing hp
any questions?
Old 07-22-2009, 02:07 PM
carte89's Avatar
Yea you didn't anwer my original question which was van you wash out your cylinders with to much fuel on a diesel motor. And when should one worry
Old 07-22-2009, 02:15 PM
dieselfreak21's Avatar
I have heard but never personally verified, that is you let the common rails idle for to long and especially if not at operating temps it will wash the cyclinder walls. I know over fueling can help cool the pistion so you get some benifit but not sure if that is possible on a common rail from what I read. I would think any time your adding extra fuel your going to get some so the question would be when you are doing anything over stock or idling to long when should you be changing the oil and how good your filter is. I could be and have been known to be wrong.
Old 07-22-2009, 03:12 PM
AH64ID's Avatar
Like dieselfreak said cylinder washing only occurs at low combustion temps.. so extended idling.. it will not happen under load.
Old 07-22-2009, 03:23 PM
Winner winner chicken dinner!
RyeThomas's Avatar
Thier are alot of guys running dual pumps and large injectors on their Daily Drivers and I have never heard a valid report of someone washing down. I wouldnt be concerned unless you plan on running 2 pumps and garden hose sized injectors on your DD, haha.
Old 07-22-2009, 08:34 PM
BigDave12768's Avatar
We have a 05 bus with a Dmax and I swear its cylinder washing. Its sits and idles terrible usually. High idle features really makes it sound bad. But if you sit with it running for say 20 minutes and then take off. It knocks and blows black smoke. I could tell my boss about it but he would just try to blame it on driver. We had a brand new Chevy bus blow an injector. Driver called in saying motor was fluttering and skipping a bit. He said nothing I can do for you behind desk. Get it back here. Bus broke down. Had to be towed. 2 bad injectors that cost him 2300 to fix chevy wouldnt warranty becuase it went into limp mode and he cleared code by turning key to try ot get it back. ECm showed it was driven 39 miles with warning lights on.
Old 07-23-2009, 08:10 PM
king d's Avatar
i have 5x15 injects wich are pretty big and very loose piston to wall clearance and i never add oil by alowing excessive idle.in fact i usually idle my truck at least 45 minutes so its ready to beat on when i drive it...
jmlcolorado
12-16-2009 04:43 AM
PourinDiesel
15
06-16-2008 09:51 AM
Camarogenius
19
03-29-2007 10:44 AM
Wes C
12-24-2002 12:28 AM
csaverline
12-08-2002 07:18 PM
Quick Reply: to much fuel?
