mp-8
Old 01-28-2008, 04:34 PM
yoda76's Avatar
mp-8
Hey all where do you all run your mp-8's at 0-100? just taking a poll.
Old 01-28-2008, 04:38 PM
Luvnacumns's Avatar
40%!!!!!!!!!!!!!
Old 01-28-2008, 05:27 PM
omaharam's Avatar
With stock injectors you should never exceed 50%. Now that I have some Fluxs I run it 50-60% most of the time but occasionally turn it higher.
Like last night.
I was sitting at a light and another CTD turned onto the road I was on and eyeballed me as he let the black cloud billow from his 6" stacks. I got skeered and flipped it to 4x4 and turned the Juice to HOT and the mp-8 on 100%. Pulled up to the next light and it was on. Let's just say I could have left the mp8 off and the Juice on 4. I always feel bad when I whoop up on a fellow CTD owner.
Old 01-28-2008, 05:59 PM
Luvnacumns's Avatar
Like last night.
Now you should be doing that!!!! LOL....
Old 01-28-2008, 06:09 PM
Billm2004's Avatar
I run mine @ 40-50% daily and at the track i turn it up all the way!!
Old 01-28-2008, 06:25 PM
rkelley's Avatar
Sorry for a dumb question, but how exactly does increasing the fuel pressure give you so much more horsepower? As I understand it, the MP8 is just a pressure box.
Old 01-28-2008, 06:33 PM
MikeyB's Avatar
Because more fuel is being delivered with the same amount of duration from the higher pressure. Also there's a slight timing advance that comes from the higher pressure when the injector fires.
MikeyB
Old 01-28-2008, 07:31 PM
rkelley's Avatar
MikeyB
Thanks for the answer. Given more fuel is delivered at the same duration, do pressure boxes make fuel economy much worse under the same driving conditions?
Old 01-28-2008, 07:38 PM
MikeyB's Avatar
Really depends. I ran a Edge EZ pressure box at level 2 (50hp) and saw a slight decrease in fuel economy for city driving, and no change on the highway.
MikeyB
Old 01-28-2008, 07:43 PM
rkelley's Avatar
MikeyB
Cool. Thanks for the info...
Old 01-28-2008, 08:00 PM
yoda76's Avatar
mp-8
thanks for the info. Does anyone tow with mp-8 and what would you set it at or what have you set it at while towing and had good experience with it.
Old 01-28-2008, 08:42 PM
bish1's Avatar
I run mine on 40-50% all the time. After hearing some of the posts here i contacted T/S Tech , and they told me 0-100% would not matter. Also said no injector problems have been reported. So, if there is any issues with running it at a higher % , they should be contacted.
Old 01-29-2008, 06:13 AM
yoda76's Avatar
bish1, I'm assuming you still have the stock injectors?
Old 01-29-2008, 06:22 AM
Kenny D's Avatar
i run mine 100% most of the time for about 20,000 now with no problems the boys at Ts performance told me 100% wont hurt it at all.
How is running it 100% any worse than stacking it with a smarty or somthin and runnin them both 50% ?????
Old 01-29-2008, 07:24 AM
Hintz's Avatar
b/c the smarty doesnt add pressure
