mp-8 and boost foolers
Old 08-14-2008, 07:58 PM
kruegerlouie's Avatar
is there a boost fooler that stacks with the mp8? i got the quad fooler but its not compatable with the mp-8, my smarty with the mp8 kept giving me codes.
Old 08-14-2008, 08:10 PM
Spooler's Avatar
Hmmmm, the MP-8 should have a boost fooler in it.
Old 08-14-2008, 09:43 PM
tritont's Avatar
if your MP-8 is anything like mine.... it has to be turned up past 60% to fool. According to TS, that's not right. Mine will be getting the once over to see what the deal is.
You don't need the quad with a MP-8 though.
Old 08-14-2008, 10:59 PM
mpracehemi's Avatar
So if I bought a MP-8, I take off the boost fooler I already have??
Old 08-15-2008, 03:18 PM
spoke w/ts today they said the mp8 boost fools on the whole range and the smartys mess with this feature when stacked so thats kinda worthless im thinking. even on tnt-r rp set on wild im only getting 25 ish on rp.
Old 08-15-2008, 03:53 PM
mulisha's Avatar
what do you mean only 25,000, thats fine.
Old 08-15-2008, 05:53 PM
cquestad's Avatar
My Smarty plays great with the MP-8.
It should fool all the way...0-100 percent.
I have fooled and true boost gauges on my truck.
I have NO idea why Dennis would not give a thumbs up to his MP-8 and the Smarty...it is a proven Stack to fine tune the rail pessure. I use RP3 and 25-33% of my MP-8 to give me 26ksi.
Old 08-15-2008, 06:09 PM
wap
wap's Avatar
I have an older mp8 (maybe 3 years old or so, I got it used) and I have never had boost fooling issues at all. But I have hear of others that have, I wonder if it is a newer version or something?
Old 08-15-2008, 06:14 PM
a little more wold be better. ive been getting codes without the quad fooler,but the mp8 wont work with it. i tried plugging it in after the fooler and it sounded like a hopped up 12 valve lopping with 25k at idle mp8 at 0!!!
this was on stock programming.
Old 08-16-2008, 01:30 AM
Asher's Avatar
you have an issue with your MP-8 then, I would first look at the back of the **** and make sure all the electrical connections are not touching each other.. Sounds like your shorting out...
Old 08-16-2008, 01:35 PM
it worked fine,i just unpluged it to install the fooler.
Old 08-18-2008, 11:01 AM
cquestad's Avatar
Did you leave the rp sensor unplugged?
Old 12-31-2008, 06:27 PM
Megaramasaur's Avatar
I just installed my MP-8. I left my quad boost fooler on. I connected the MP8 (blue connector into the map sensor next to rail, then connected the other end into quad, then into Wire lead connector to computer. I got no codes, and the MP8 works like a charm... The only reason I kep the Quad tonight is that my Commander is tapped into the Quad boost fooler blue wire (pre boost fooler). If I lose the quad, where do I tap for the boost guage?
Will it hurt anything if I have the quad, mp8 and smarty boost fooling? I wouldn't think so... I can still hit 50psi with no codes.....
REDNECK-WELDING
04-02-2009 03:24 AM
qzilla
02-01-2009 12:28 PM
mpracehemi
08-31-2008 04:11 PM
BigJohnston
30
03-02-2007 12:39 AM
dditt0635004x4
10-18-2006 03:18 PM
Quick Reply: mp-8 and boost foolers
