Mopar cold weather front
Old 10-25-2006, 04:18 PM
BMH95's Avatar
I went to install my mopar winter front cover the other day, and noticed that I have 3 rips in it. They are all from the little lower hook deals that catch the three holes in the bumper. Did anyone else have this problem?
Old 10-25-2006, 04:42 PM
redspider's Avatar
i did, I removed it after 5 months of service and returned it to the dealer for a new one. they did NOT want to give me a new one, I had to remind them that it was a genuine mopar product and that it should have a 1 year warrantee. Parts guy was a little more responsive after I pushed back, he said he'd send it away and see what they said about a replacement. Next day I got a call and a new boxed one was waiting for me to pick it up.
I put my new one on the other day and it seems to be making a whistle noise. Only way to describe it really, like a really bad wind noise coming from the front end. I will have to inspect it soon.
But I think at the speeds I travel its only a matter of time before it rips again!
Old 10-26-2006, 12:28 AM
SuperGewl's Avatar
I'll double check mine later this week. I've had mine for 2 years and have'nt notice any, but I don't hook the bottem hooks because the holes are plugged with the Fog light harness holders.
Old 10-26-2006, 09:17 AM
BMH95's Avatar
Mine had the fog light plugs too, so I popped the plugs out and secured the loom with small zip strips. That way the hooks would attach. I've had mine for about a month past one year, so I'm stuck with it. I'll have to try a good cleaning, and some black duct tape. If the tape doesn't work, I'm sure a shoestring will.
Old 10-26-2006, 09:51 AM
cdru's Avatar
Mine also has the fog light wiring harness plugging the holes. I found I could pull the hooks toward the radiater and the hooks will hook on the bottom of the first radiater. Works well. cdru
Old 10-26-2006, 02:26 PM
6 2 Carl's Avatar
Do you have the Dodge bug deflector on the hood? Mine makes a whistle noise when both the bug deflector and winter front are installed. Remove the bug deflector for the winter and the whistle will go away.
Carl
Old 10-26-2006, 04:48 PM
redspider's Avatar
Carl
Carl!!!! Thanks for the reply! I do have a bug deflector that I just put on this spring, totally forgot that it wasn't in place last winter when the winter front was installed. thanks again for the tip
Old 10-27-2006, 01:42 PM
Robert373's Avatar
Carl
I second that Thank You. My Mopar winter front drove me crazy last winter because it wind whistled constantly. Tried everything I could think of to cure it, and eventually got tired of it and just took it off. Never thought about the bug deflector.
Old 10-27-2006, 02:31 PM
grandblanc's Avatar
anyone who uses the winter front cover and have a trans temp gauge notice if the trans temp runs higher with the front cover on? could this lead to more trans failures?
Old 10-27-2006, 02:37 PM
FOXY005's Avatar
I found that if when you are installing your winter front, you
attach the bottom hooks first. It makes it a lot easier to install.
Exactly the opposite of the instruction sheet that comes with
the Mopar Winter Front, Go Figure !
Old 10-27-2006, 04:53 PM
goose2's Avatar
I noticed with a peice of card board in front of the radiator only did make my tranny temps higher. They run around 170-180 without any cover. With the cover it will go to 190-195. I was going to put a winter front cover on mine. But The last test showed me not to cover it "all" up like the mopar cover does. I will just keep using my little peice of card board with a hole cut in the center of it. It works just fine and cost alot less. I am not sure I want the higher temps the front cover brings on.
Old 10-28-2006, 09:31 AM
topless's Avatar
I had one of the hooks that go on the bumper support rip out. I drilled 3 small hole in it and re-attached it to the cover with zip ties. The zip ties goo around the renforced edge and seemed much strong than before.
Old 10-29-2006, 11:51 AM
coobie's Avatar
I have had the mopar winter front now going on my third year.I have a tranny temp gauge and have not seen any really high tranny temps.useing the winterfront.I install the winterfront mid Nov.and take it off mid March.coobie
estesbubba
10-17-2006 09:22 PM
LCH
10-30-2005 07:07 PM
AMERICANPIE
07-15-2005 02:44 AM
joel
01-22-2005 08:59 PM
wings
11-08-2004 05:32 PM
Quick Reply: Mopar cold weather front
