Moog Trackbar, Dead after 6,000 miles?
Old 03-11-2007, 07:42 PM
Common's Avatar
Its under warranty, but seriously, how could this happen?
Up and down play where it connects to the frame...
Old 03-11-2007, 08:14 PM
Danderson's Avatar
3rd gen trackbar
I replaced mine with a 3rd gen setup. Cured the wander as much as you can on a 2nd.
Old 03-11-2007, 08:47 PM
Common's Avatar
How do you go about doing that?
Old 03-11-2007, 08:57 PM
Scramblinman's Avatar
Solid Steel
Old 03-11-2007, 09:28 PM
TIMMY22's Avatar
if you have up and down play, try to re-torque the nut.
Old 03-11-2007, 09:29 PM
Common's Avatar
I thought of that, but this bar doesnt have a grease fitting, and the bolt doesnt move, just the bottom...
Old 03-11-2007, 10:39 PM
TIMMY22's Avatar
They can wear fast, especially with dirt roads and snowplowing. 6,000 miles seems a bit premature. Take the carter pin out and see how much force it takes to spin the nut. I'll bet it's loose.
Old 03-12-2007, 12:51 AM
1stGen545's Avatar
get the Solid steel and DSS steering box brace. I have it and it steers great and has no slack and dose not wander. The stock bar with the ball joint is junk and for a ball joint to work right it needs the stud to be 90* to the bar and load. Dodge puts it at about a 35-40* which tries to pull the ball out of the socket. The 3rd gen bar has a bushing at both ends.
Old 03-12-2007, 09:57 AM
infidel's Avatar
What I've found replacing trackbars is the folks who drive fast on pot holed roads go though them very fast.
Old 03-12-2007, 05:58 PM
xtoyz17's Avatar
Oops. Guess I'm guilty of that
Old 03-12-2007, 06:13 PM
Joseph H. Smith's Avatar
Track Bar
My first track bar lasted 100,000 miles. I am on my second and it has 52,000 on it and is still within specs.
Old 03-12-2007, 06:27 PM
Valv's Avatar
Originally Posted by Scramblinman
I wish they list their prices, I hate the long "hunt" and the requests for a price.
If it's too scary to post on their web site they shouldn't sell them.
I need a trackbar now and I need a price, this old style salesman tactics are very annoying, in fact I will buy somewhere else.
Old 03-12-2007, 06:36 PM
Valv's Avatar
What's the difference with a 3rd gen ?
Old 03-12-2007, 06:52 PM
Common's Avatar
I agree 1000%
Old 03-12-2007, 09:09 PM
1stGen545's Avatar
The 3rd gen uses the bushings at both ends like the one on the axle that you have now. PRD sells the track bar retrofit kit for $175, the bar for $235 ( or you can get it at the Dodge house) and the steering bracket for $189, and worth every $. My brother with a 02 3500 4x4 went threw 3 new bars from Dodge in less than 100K. Also 2 steering boxes. He towed a lot ( backhoe, fork lift, and lots of steel, and a 11K utility trailer every day. Only a little dirt road and they would still where out all the time. We only found out about the kit about 6 months befor he sold it. Put it on and it drove better than when he bought it with 23K. I have the kit now. I find if you use your truck the bar will go out soon. Most people just live with it. You may think your truck is in good shape until you put this kit in.
EverydayDiesel
77
01-27-2018 02:38 PM
mommak
18
02-15-2012 07:17 AM
mommak
17
02-13-2012 12:36 AM
biglar
07-23-2006 11:42 PM
getblown5.9
06-26-2006 07:35 PM
Quick Reply: Moog Trackbar, Dead after 6,000 miles?
