Mods advice please
Mods advice please
I am considering the following for my 01 and looking for advice
275 injectors
boost fooler
bypass wastegate
remove muffler and replace with staight pipe
have replaced air filter with K&N
don't need too get too radical but would like a little more
I have decided against a box for now but I read that the injector change should give a little kick.
275 injectors
boost fooler
bypass wastegate
Re:Mods advice please
[quote author=eieio link=board=4;threadid=21834;start=0#msg204393 date=1067721909]
[/quote]
Not much, but add an EZ with them and you will feel the difference.
[/quote]
I agree.edge boxs have mega bang for the buck.I have a comp box and just love it.Its off half the time and powered up to #5 when I feel a little frisky and want to trounce a ford or something.
I did not see gauges in there anywhere. If you are going to add fuel you will be adding heat. The way I would do it is :
1 Gauges to get a base line and protect your equipment.
2 Tranny upgrade. You will be surprised how much power that is not getting to the rear wheels. >
3 Power and more power. ;D
Just my 0.02 worth.
Good luck.
Just my 0.02 worth.
Good luck.
What BILLG said!I did not see gauges in there anywhere. If you are going to add fuel you will be adding heat. The way I would do it is :
Just my 0.02 worth.
Good luck.
;D ;D :P
Just my 0.02 worth.
Good luck.
;D ;D :P
CTDjoey
08-04-2008 09:59 AM
dodgemaniac
Competition / Pulls / OffRoad
07-31-2008 10:15 AM
