modified injectors?
Old 10-16-2006, 07:14 PM
joelegs1000's Avatar
modified injectors?
I figure this is the place to ask, Is it possible to have you stock injectors modified to create an additional 100hp. I dont know much about it but heard for $300 for 100 hp, sounds good to me. Also is it a good idea or bad. thanks
Old 10-16-2006, 07:23 PM
Luken's Avatar
Formula 1 Flux injectors is what you need.
Old 10-16-2006, 07:32 PM
Would that require any other upgrades and what does that run$/hp increase. I dont have to much done to my truck but Im starting to finally do stuff to it.
Old 10-16-2006, 08:01 PM
Just did a search on those and nothing would like to know more.
Old 10-16-2006, 08:37 PM
masonic-dodge's Avatar
Just because they are called 100hp injectors, doesn't mean that your going to get 100hp! You also need FUEL to supply them.
With that said, "GO FLUX" or don't go at all, just my 2cents
CRIS
Old 10-16-2006, 11:01 PM
wcjp's Avatar
I'm running DDP injectors. Not sure about the current cost. I ended up with 83hp.
Old 10-17-2006, 07:09 AM
Jetpilot's Avatar
Look here: http://www.performancedieselwarehouse.com/793379.html
Doug Smith
Old 10-17-2006, 07:15 AM
deezulsmoke's Avatar
Check this site out if you are not wanting to empty your pockets for 100 hp.
http://gethoned.com/diesel.php
The only difference is the extrude honed may smoke a little more than the EDM machined injectors. For around three hundred bucks you can send your injectors into that website and have them honed out. Hope this helps. Unless you are really modding the engine I would not spend the money on the f1s.
Old 10-17-2006, 11:04 AM
CATCRACKER2's Avatar
"gethoned" the link doesnt work i would like to check these guys out
Moose10
12-02-2005 03:15 PM
Jones0027
37
09-19-2003 01:46 PM
dodgeman01
02-14-2003 12:13 AM
mxboy
12-07-2002 12:36 AM
Quick Reply: modified injectors?
