about to mod the pump...
i'm using the directions from http://www.dodgeram.org/tech/dsl/mor...r/Power_ve.htm i'm having a little troble even finding the full power screw, can someone help me out! thanks
the directions say it's under a "plastic cap" well i found a cap... but i as far as i can tell it's painted metal and i can't figure out how to get it off... also i want to make sure it's the right one!
Remove the whole power screw so you can get at it, then you can pry it right off. Just leave the lock nut where it is so you have a reference of how far to screw it in.
There's a little sheetmetal washer and a big o-ring that will fall off when you pull the screw out, they are not important and don't need to go back on. Also some fuel will leak out when you remove the screw.
when i spun the lock collar... the screw spun as well.....
1 do i just continue to spin till it all comes out?
2 after the fuel comes out, are there any special things i have to do to start it?
ok the collar it off.... it ruined some of the threads though... lookslike it would go 3 1/2 turns before it hits the bad threads. i don't plan on turning it nearly that far.... what incriments should i change it in?
ok, i gave it one full turn and i like it VERY much! can't imagine what it'd be like with a 16 instead of the 21
what did you guys use to tighten the lock nut... a socket? i can't seem to fit the ratchet in there, have a breaker bar, but couldn't get the correct angle to get it to work. idle is up to about 1000 i will fix that tomorrow
1/2 inch (13mm) wrench can be wormed in there with some patients. Hold the power screw with a flat blade screwdriver and twist the wrench...it helps to have the throttle rod disconnected. Think about investing in a 13mm gear wrench
g
g
Kenworth
Jul 15, 2008 04:18 PM
jmccart
Dec 19, 2007 12:49 AM
jamesbfishin
Jul 7, 2007 08:25 PM
wap
Apr 23, 2007 06:46 PM
RAMV
Jul 14, 2004 12:08 PM
