Mod Money
Old 02-20-2008, 06:30 PM
marine4life's Avatar
Mod Money
I've been racking my mind over what mods I want to do next. Im trying to stay in the range of 3-4000, so twins are out of the picture for right now. I know my factory turbo is hating life right now pushing 40 pounds of boost on a Level 5 run, so a bigger turbo is a must along with some Mach 4's to spool it. I do eventually want to move to a twin turbo setup so I thought maybe the Super B would be a good choice. I want to stay around 500 ponies until I get more money. I am definitely going to sell my Edge Juice and buy a quadzilla, test drove a truck with one the other day and I couldn't stop smiling, the low end is absolutely amazing. Also, is a new cam, such as a F1 Helix 2 a good investment, or not really a nescessity in my setup? Any help you guys could offer would be appreciated, I want this money spent on the right stuff the first time.
Old 02-20-2008, 06:35 PM
Adam3291's Avatar
Rodney (Metalman) made 514/1100 back in November with his 01 automatic running Juice w/ Attitude, Mach 4's and a HTT HTB2 62/12. The good think about getting something like a 62/12 or a 62/14 is they make on excellent top charger in a twin set when mated with a S400 under it. Rodney has done the same thing you want to do, move to twins. He just got his head ported/o-ringed along with F1 valve springs preparing for twins. He is going to use his 62/12 as the top charger.
Quadzilla doesn't have the monitor out just yet for the Adrenaline. Don't know how long that will be. If you don't have the Hot Juice I would give that a try first for $100. You can find a good set of used Mach 4's for about $700, once in a while a 62/12 gets sold on here for $1000, thats what pete2141 sold his for recently. I would get a good Southbend clutch. For your setup right now I would say a Helix 2 is not needed.
Old 02-20-2008, 06:49 PM
sorry, I haven't updated my sig, when I pulled the transmission last weekend I checked the clutch that was in it, it is a MU 13-1.25 Con FE. I knew it had an upgraded clutch in it when I bought it, but just didn't know what one. Although it has a VERY rough engagement sometimes, it holds all the power I can throw at it. I REALLLY want to get a quad adrenaline, but the guages on the edge are nice. Kind of torn right now.
Old 02-20-2008, 06:53 PM
Adam3291's Avatar
Well thats good you don't have to worry about the clutch The good thing if you get the Hot Juice you can resale it for a little bit more so you don't lose to much. I think everyone else will agree Mach 4's and 62/12. If you bought all that new I would say $2000 to $2500. Are you currently running the water meth as well?
Old 02-20-2008, 06:55 PM
I've only used the water/meth a few times, haven't really tuned it in. When I punch it in 5th gear it makes the engine stutter a little bit. Kind of worried about the head gasket.
Old 02-20-2008, 06:58 PM
Adam3291's Avatar
Exactly what I was getting to , a set of 12mm studs right now would be good insurance for the time being. I want to get mine to 500-550 on fuel only, I'm going to get a set of studs to be on the safe side. I'm sending you a PM about some injectors I know about are for sale!
Old 02-20-2008, 07:16 PM
Will a set of 12mm studs by themselves hold up, or is it nescessary to get the head oring'ed.
Old 02-20-2008, 07:33 PM
Adam3291's Avatar
The studs will buy you a little more time but you need to get it o-ringed.
Old 02-20-2008, 08:08 PM
Sounds good, will probably have to invest in some studs as well then. Thanks for the help.
Old 02-20-2008, 08:42 PM
Troutstrannysvc's Avatar
I would suggest while you have the head off to go ahead and get it resurfaced. O-ringed 300-400$, and #60 valve springs in...
This is going to save you a lot of time in the future.
jamesbfishin
07-07-2007 08:25 PM
JDeere5105
06-10-2007 07:42 PM
wap
04-23-2007 06:46 PM
KAyers
01-27-2007 11:02 AM
RAMV
07-14-2004 12:08 PM
Quick Reply: Mod Money
