mirror problem
Old 10-13-2006, 08:06 PM
socal 610's Avatar
mirror problem
Hi,the problem is when I have the driver side mirror in the towing position it gets stuck from moving left or right.I can force it thru the spot it hangs up on but does not work as normal can anyone relate to this and maybe have a fix...Thanks in advance
Old 10-14-2006, 08:17 AM
MiGunner's Avatar
sounds like you may have a wire from the harness interfering with the movement of the glass. Push the glass all the way to one side and look in there to see if something is interfering. You may have to use a flashlight to see.
Old 10-15-2006, 10:51 PM
BigHornCTD's Avatar
I have a similar problem, except mine wont go up or down when it is folded in the normal driving position. It has been that way since the day after I bought the truck. I haven't had a chance to take it to the dealer yet.
Old 10-18-2006, 02:19 PM
H BROWN's Avatar
both of my mirrors would not go up or down the day i bought it, and they replaced both with no problems so far.
Old 10-18-2006, 06:17 PM
socal 610's Avatar
thanks for the help guy's the dealer put a new driver side mirror on
jethroish
03-03-2014 10:09 PM
cj5er
12-20-2009 09:19 PM
capsparky111
02-05-2008 09:34 PM
Buzz
11-19-2002 09:49 PM
Quick Reply: mirror problem
