mileage
mileage
Hi I'm new to the diesel scene,I'm looking at a 2006 3500 dually 4wd.It has 460,000 kms on it with new clutch and a banks turbo.Should I be worried about anything? thanks
Welcome to the DTR!
286,000 miles is quite a bit on an '06...
I would go over everything and make sure you get a good deal on it, knowing repairs may be coming.
Good luck!
Good luck!
the kdp (killer dowel pin) is a 75 cent part that can destroy your engine. It lines up the gear case on the front of the motor and the motor vibration can cause it to come loose and then bounce around the gear case. Best case, if it does come out, it will drop into the oil pan. Worst case, it will drop into the case gears and bust things up REALLY bad. Its a few hours to do and not that hard of a fix. Ask the current owner if its ever been done.
Since you're talking KM, where are you?
You can start here:
http://www.genosgarage.com/TDRBuyersGuide2009.pdf
and
http://www.genosgarage.com/faq.asp
and
Received 1,637 Likes
You can start here:
and
and
Thank you
GLHS
02-13-2009 07:58 PM
zack birge
20
07-11-2008 10:29 AM
slowstang232
03-31-2008 08:23 AM
Kman9090
09-19-2006 11:25 AM
TxDiesel007
17
01-17-2006 02:54 PM
