Mileage Sucks
Mileage Sucks Help!!!
I have a 06 mega cab 3500 dually with a diablo set on economy and i am making 13.1 and that is driving like an old man any suggestion... Help cant afford that.
how many miles on her?? takes about 20,000 miles to break her in. i have 80,000 miles on my 04.5 with the edge juice and i get 17 mpg doing 50-50 driving- no matter if i drive her hard or like a grand ma. i can get 21 mpg on the highway if i keep her under 2000 rpm's. the only major difference between our trucks should be- i have dyna-trac lock out hubs and you should weigh a little more.
I have 78000 miles on it have been told that it might be an injector or something because it idles pretty rough and also when i let of the pedal going down a hill or something it will be like its not getting enough fuel like it is choking it.
Is this something new, or has your mileage always been this bad? If the truck has a standard trans, low axel ratio, been raised, or has big tires, all these things will lower the mileage you can expect from your truck. If this is something new you can check the usual suspects like a dirty air cleaner, low tire pressure, etc.
i bought the truck when it had 54000 miles on it and havent done anything to it except for a diablo sport and i run it on economy stage and drive like an old man and i still get 13.1 and on highway 15 which i hear everybody making 17 on theres so i was just wondering what is wrong it is a 06 megacab dually 5.9 with stock tires and everything
that's real bad. i do mostly highway driving, and can pull 20 mpg pretty easy, with 3.5" lift and 35" toyo m/t's. i would start with the easy stuff (air and fuel filters), and then go from there- something is not right.
does having drw make a big difference? i never really thought that much about it, but it makes sense that it would.
YA i noticed that when ever i am going down a hill it will act like it is choking it self so i am going to change the fuel filter and see thanks!!! i will post back and let you know... If yall can think of any other reason why it would do that let me know PLEASE cant afford it.. THANKS!!!!
I've got 06 mega cab 3500 4x4 non dually and only see 15 tops driving like an old man. Very disappointed in the MPG on this vehicle. Love it other than that. I'll this hype about the smarty jr, I'll guess I will buy one.
I'm getting 15 MPG mixed driving with the lift and 35s. I won't claim to baby it all the time, but when on the highway I'll make sure to keep my RPMs right at 1800-1900. Just out of curiosity, is it an auto or manual. Also, on the highway, how fast are you going, what RPM are you at?
