Mean-Green 205amp Alternator......
Old 06-29-2007, 04:58 PM
Hammer's Avatar
With all the additions to my truck recently and adding more electrical parts(FASS and Flex-A-Lite Fans) I figured I better head off a problem before it arose and BOMB my charging system.
For that I contacted Mean-Green Inc here in Pennsylvania as they make a NEW,not rebuilt,alternator that is 205amp and a direct bolt it.Well it didn't come in so we could install it with the fans so I got some time today and did the install.To say I wished it was here while we did the fans is a understatement,LOL.I had to remove the fans as I could not get the long bottom out,dooohhh.
Anyway,I got the old one off and unhooked and retired it to the,who knows if I will ever use it again bin(there is alot of parts from my truck which ended up in there) as it will now be a spare.The new one was a direct fit,utilizing the factory wiring harness and mounts and ws a relatively easy install once I got beyond my fan setiup.
After reinstalling the battery cables and making sure I had the belt straight I went and fired her off.I noticed immediately the difference in alternators on the volt gauge.Before at ilde right of a start it would come up and stay around 13.0-13.4v.The new one after starting went to 13.9 and stayed there and only drew down to 13.4 with all my electricial gadgets on(fans,FASS,headlights,A/C and stereo).Its a nice unit which is a option for those of you who may want to BOMB your charging system next.......Andy
http://mean-green.com/index.html
Attached Thumbnails Mean-Green 205amp Alternator......-pictures-200.jpg   Mean-Green 205amp Alternator......-pictures-201.jpg
Old 06-29-2007, 07:33 PM
afoulk's Avatar
hammer, where in PA are you from? I'm in the Lebanon area, about 30mins. east of Hershey. I thought of going with one of those alternators myself, but they were a bit more than I wanted to spend at the time.
Old 06-29-2007, 10:24 PM
Hammer's Avatar
They are in Derry,PA which is located Northeast of Latrobe,PA.They are not cheap,but,then again alot of times cheap doesn't mean it will last.This is a quality unit NOT rebuilt,built from all new parts.That alone is worth alot to me....Andy
APD
04-17-2015 06:22 PM
EdmontonCanada
08-11-2012 10:38 PM
Quick Reply: Mean-Green 205amp Alternator......
