mating an MBRP 4" AND 4" Cooleeze Megamouth
Am thinking of this combination. But having not looked underneath in a while, how much of the MBRP exhaust needs to be cut to accommodate the Megamouth?
You will prob be able to take out the MBRP DP and put the Cooleeze DP in. If its just the Cooleeze elbow that replases the cast part it will bolt right in.
I looked into this before deciding I didn't really need the Megamouth...yet. Jeff at MBRP could probably tell you, or maybe someone at Megamouth. If the downpipe is belled on the end, it would be easy to cut the MBRP before it turns toward level and clamp it, but you may have to uninstall your exhaust to fit it back together. Jeff is at 888-636-7223.
macjazzy
27
04-04-2007 04:51 PM
Jordan5687
02-14-2007 05:00 PM
